Op-pro hum
ocharms
Posted 2007-07-08 5:53 PM (#90988)
Subject: Op-pro hum
July 2007
I own a brand new Legend Lx 2077 with an op-pro studio preamp, it's my first Ovation. It has worked fine for the last weeks, but now I'm hearing a low buzzing noise through my AER-amp, even with drive and gain on the Op turned down. It has become louder with a new battery installed. Is this a known issue with the op-pro studio?
Posted 2007-07-08 5:58 PM (#90989 - in reply to #90988)
Subject: Re: Op-pro hum
check your cable, maybe swap it out.
make sure the internal connections from the jack to the preamp and the pickup to the preamp are all solid
Posted 2007-07-08 6:01 PM (#90990 - in reply to #90988)
Welcome. Very nice guitar.
Don't recall anybody having this problem but someone will chime in with suggestions any minute I would think. Tho Sunday evenings are not the busiest time here - most members like to post while they're being paid to do something else.
If the guitar is new it will still be under warranty - take it back to the dealer if nobody comes up with an obvious solution.
ocharms
Posted 2007-07-09 5:25 AM (#90991 - in reply to #90988)
July 2007
thanks for the replies so far. Cables were are solid. I have the idea that the drive-knob in connection with the exciter doesn't work at all, though I realize it's a subtle adjustment. Perhaps that's what causing the hum. Bad luck. It's really a fine instrument with a natural cedar top. Hope someone comes up with a solution, otherwise, I'll take it back to the dealer.
mtnbikerfred
Posted 2007-07-09 2:19 PM (#90992 - in reply to #90988)
Yeah,
Subtle... Best described like being hit in the head with a brick wrapped with a twist of lime.
To quote myself:
The "Expessor" slider *should* say "Skinny" at the bottom, and "Fat" at the top.
The "Drive" control should maybe be labelled "Growl" or perhaps "Rumble"and should me marked that it goes to "11".
I believe you may have a bad pre-amp. Work with your dealer or contact the mothership.
ocharms
Posted 2007-09-10 1:47 PM (#90993 - in reply to #90988)
July 2007
Well, the story continues..I took it to the dealer and yesterdayI got my guitar back (after eight weeks). Nothing has changed. It's still there, the hum. I've made an MP3. This is what I hear with the gain on the Op turned down and the volume on the amp a bit up:
http://www.gitaarinfo.nl/mp3/50hz.MP3
Am I mad? Is it paranoia?
LBJ
Posted 2007-09-10 1:52 PM (#90994 - in reply to #90988)
March 2007
sounds bad.
but try to connect other guitar to Your AER.
it might not be problem with Your guitar.
Posted 2007-09-10 1:53 PM (#90995 - in reply to #90988)
Have y'tried it with a different amp??
LBJ
Posted 2007-09-10 2:03 PM (#90996 - in reply to #90988)
March 2007
one more thing. look if there is no short-circuit on wires from battery to preamp.
ocharms
Posted 2007-09-10 4:11 PM (#90997 - in reply to #90988)
July 2007
It's the same on my other amp (JC120)...
Posted 2007-09-10 4:30 PM (#90998 - in reply to #90988)
A longshot, but try a different outlet, or make sure the outlet you are using is properly grounded, and if all else continues to fail, shut off all the neon signs.
ocharms
Posted 2007-09-11 7:05 AM (#90999 - in reply to #90988)
July 2007
Thanks to everyone for thinking about solutions. but really nothing works. Even shutting off the pizza delivery sign. I've asked the dealer to take it back. And to be honest, I don't know if I would take a chance with an Ovation again. Or perhaps an older model with an traditional Op....
Posted 2007-09-11 7:34 AM (#91000 - in reply to #90988)
Email John Budny at Ovation. It's very likely he will be able to make things right for you in a short time.
tpa
Posted 2007-09-26 8:29 PM (#91001 - in reply to #90988)
... Is it paranoia?
Probably not. That has a different sound. I had hum experiences with two Ovations and no real support from the representative. One Celebrity and one Adamas. The good service and guarantee is only for US (and apparently south-african) customers. So if you depend on the electric function I think reversing the deal is a wise step.
