OT - restringing a bigsby
HobbyPicker
Posted 2007-07-28 8:27 AM (#88500)
Subject: OT - restringing a bigsby
I love the look and feel of the Bigsby trem on my electric, but not when I restring it. Is there any good and easy way to do this in without finger acrobatics to keep the ball ends in place while tighting the strings? :confused:
Would probably make my electric happy with fresh strings more often!!
Posted 2007-07-28 12:29 PM (#88501 - in reply to #88500)
Subject: Re: OT - restringing a bigsby
tape the string on the post, then tighten. then tape the next one.
vision
Posted 2007-07-28 12:33 PM (#88502 - in reply to #88500)
July 2007
I have a guitar with a bigsby - take 2 xanax and a shot of tequila - it will make it much less frustrating that way. Never thought about taping the string - Good idea!!!
dvd
Posted 2007-07-28 2:14 PM (#88503 - in reply to #88500)
Are you doing the 45-degree kink trick? That helps. Haven't tried it, but I've heard a little home-made wedge made out of styrofoam or cardboard helps.
PS, and it's not OT! I have a Bigsby on my Ovation Eclipse! :)
surfnguitar
Posted 2007-07-28 7:04 PM (#88504 - in reply to #88500)
August 2005
The 45 degree kink works best -keeps it from slipping off the little peg while you take one hand & crank the tuning peg, while keeping tension with your other hand. One of those goobers that goes on the drill helps a lot, especially with the Bigsby.
Also, having 3 hands would help, but with a little practice it gets easier. Without the kink, it's a real pain, though. Personally, I'm kind of like Brian Setzer -I can't play without a Bigsby. Of course I can't play like him no matter what I have.
Just don't get a Rickenbacker with the "R" tailpiece - then you need 4 hands to change strings.
FlicKreno aka Solid Top
Posted 2007-07-29 9:44 PM (#88505 - in reply to #88500)
It`s a cinch....all U need are four hands and a thumb...
Kidding Aside ;...I made a cardboard template,that slides under the tremolo/bridge ,remove old string,then insert new string (at end)through peg,then ,other end ,over saddle ,under roller,over Tremolo-roller,bend under,secure at pin...on my WASHBURN J-9..see..nothin`to it.. :)
:cool: Vic
richardd
Posted 2007-07-30 6:44 PM (#88506 - in reply to #88500)
I own 3 Gretsch guitars all wth Bigsby's.
As DVD said, you need to make the kink in the string to help keep it on the pin.
As long as you keep the tension on the string as you wind it you should have no problems.
Contrary to rumor, Bigsby's work well and stay in tune providing the guitar is set up correctly.
This is from the official website:
Question: Is it difficult to re-string a Bigsby?
Re-Stringing the Bigsby Vibrato
1. Crimp the string at a 45 o angle next to the ball end (A).
2. Feed the string underneath, around and over the axle (B).
3. Place the ball end of the string onto the axle pin (C), keeping tension on the string to hold the ball in place.
4. Push a foam wedge (D) into the space under the axle to keep the string in place on the pin while winding.
5. Wind the string onto the tuning machine, tune to pitch and remove the foam wedge.
6. Repeat for each string.
Posted 2007-07-30 8:02 PM (#88507 - in reply to #88500)
I disagree with the kink in the string....that will induce tuning problems...well,a slight bend maybe.. :)
Vic
dvd
Posted 2007-07-30 9:23 PM (#88508 - in reply to #88500)
The kink is right where the string bends over the axle anyway, it gets pulled tight when you tune to pitch. Make a point to kink it in the direction the string will be pulled anyway and it'll be fine.
richardd
Posted 2007-07-31 6:54 PM (#88509 - in reply to #88500)
You're right DVD, no tuning problems at all. I've been stringing my Gretsches this way for 15 years.
Most important thing for tuning stability with a Bigsby is a well cut nut, preferably bone, graphite or slipstone.
