  | Hiya,
I got myself an old Deacon which seems to have had a bit of a hard life. Headstock broken and repaired, missing truss rod cover, damaged pickguard, missing knob, and a less-than sympathetic spray job!
I got an original 12-string neck in addition to the guitar too, so am keen to see if I can create a 12 string. To wit, I am seeking a 12-string bridge for it. I bought a 12-string bridge which I think came off a Viper but they're not the same type at all.
Does anyone know where I might source parts?
Thanks |  |
  Location: The Great Pacific Northwest | Your Viper bridge will probably work as I assume it's the all metal one.  They use different studs, but that bridge is the upgrade to the one above.  Personally, I like the original bridge as you have above, and as there was a 12-String Deacon, there are bridges like that out there.   I'll upgrade your membership as only a few people can post here in the Welcome Center.  You can re-post in the General Forum and someone may have what you are looking for. |  |
