Deacon Problems
raf
Posted 2020-04-23 1:41 PM (#551932)
Subject: Deacon Problems
January 2017
Hi All,
I have a mid 70's Deacon (humbuckers) which I'm trying to sell, I've had it up for sale since October and I tested it then and it was all working and it's been in the case since but someone contacted me the other day who is interested in it so I took it out put a couple of batteries in it and no output.
If I crank the volume up from the noise I can hear the volume, tone and notch filter are working but a very very low virtually inaudible level from the pups if I tap them with a screwdriver, I'm assuming one of the transistors has probably gone faulty so I guess I'll need to remove them from the PCB and test them, any other ideas on what it might be?
raf
Posted 2020-04-24 1:22 PM (#551942 - in reply to #551932)
Subject: Re: Deacon Problems
January 2017
Further testing reveals the JFET Q3 is faulty as I have no continuity between the gate and the source or drain in either direction, so I'll need to source a replacement.
Edited by raf 2020-04-24 1:46 PM
raf
Posted 2020-04-24 3:57 PM (#551943 - in reply to #551932)
January 2017
More testing reveals all 3 FET's are faulty, Q1 has continuity in both directions from gate to source & drain while Q2 has no continuity either way.
raf
Posted 2020-04-29 11:58 AM (#551979 - in reply to #551932)
January 2017
I've replaced the FET's and all now appears to be working :-))
numbfingers
Posted 2020-04-30 9:30 AM (#551993 - in reply to #551979)
I was going to reply to your earlier posts, got here and see that you fixed it.
Anyway, here's a thread with links to schematics:
http://www.ovationfanclub.com/megabbs/forums/thread-view.asp?tid=32...
Steve W.
