Posted 2020-03-05 5:53 AM (#551439) Subject: Savarez 520R not safe tuning 1613
Hello my friends. My 1613, after a restoration, arrived from the luthier in 2 weeks. I put strand Savarez 520R high voltage. He is not holding tuning. I ask if anyone has had this problem with this rope? Can you indicate which would be the most suitable 1613?
Obs: I apologize for any errors in the text. I am a hostage to the google handler
Posted 2020-03-05 8:30 AM (#551443 - in reply to #551439) Subject: Re: Savarez 520R not safe tuning 1613
I am guessing you are using high tension strings.
After a week or so they should settle in.
If you are still experiencing quite a bit of tuning irregularities...I would say the string is slipping...either at the bridge or on the tuner.
Those are my guesses.
If the google handler is still holding you hostage...let us know.
Posted 2020-03-05 6:07 PM (#551446 - in reply to #551439) Subject: Re: Savarez 520R not safe tuning 1613
Actually, nylon strings react to weather changes as well as everything else. I've never had a nylon strung guitar that didn't need to be tuned as soon as it was picked up. And that lasts a good long time. I usually decide to change strings when they do stay in tune and don't need to be tuned every time.
I wouldn't worry at all about having to tune your guitar. And I have always used extra hard tension strings......
Posted 2020-03-07 11:52 AM (#551454 - in reply to #551446) Subject: Re: Savarez 520R not safe tuning 1613
moody, p.i. - 2020-03-06 1:07 AM
+1 what Paul said.
When nylon strings stay in tune, they are worn out....
Posted 2020-03-09 8:15 AM (#551470 - in reply to #551439) Subject: Re: Savarez 520R not safe tuning 1613
<pre id="tw-target-text" class="tw-data-text tw-text-large tw-ta" style="max-height: 999999px; font-size: 24px; line-height: 28px; background-color: #f8f9fa; border: none; padding: 10px 0.14em 10px 0px; position: relative; margin: -10px 0px; resize: none; font-family: inherit; overflow: hidden; width: 364px; white-space: pre-wrap; overflow-wrap: break-word; color: #3c4043;" dir="ltr" data-placeholder="Tradução"><span style="max-height: 999999px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">Olá Agradeço a todos os amigos para as suas sugestões. </span><span style="vertical-align: inherit;">Eu descobri a razão para o desacordo entre as cordas de nylon e minha 1613 e gostaria de compartilhar com todos. </span><span style="vertical-align: inherit;">Esse pequeno parafuso que existe nos ouvidos dos tarrachas. </span><span style="vertical-align: inherit;">Ele atua para tornar o sistema muito apertado deixando as cordas apertado. </span><span style="vertical-align: inherit;">Tem sido 2 dias sem fora de sintonia.</span></span></span></pre>
Posted 2020-03-09 9:08 AM (#551472 - in reply to #551439) Subject: Re: Savarez 520R not safe tuning 1613
Hello I thank all friends for their suggestions.
I discovered the reason for the disagreement between the nylon strings and my 1613 and would like to share with everyone.
That little screw that exists in the eardrums.
It works to make the system very tight by leaving the strings tight.
It's been 2 days out of tune
