Ovation 1617 1979/80 great sound but...
Aran
Posted 2018-02-10 8:20 AM (#541138)
Subject: Ovation 1617 1979/80 great sound but...
January 2018
I've recently buy an old Legend 1617 , what a great guitar! But there's a crack in the top and the top itself seems to be waving (warped ) maybe due to lack of humidity . I don't know much about this guitar , the seller didn't play it in the last 3 years and told me that the crack has always been there ( He buy this guitar from a collector some years ago).
The action is ok , the sound is great so, I must do something or I can leave it as is ?
Maybe glueing the crack and repair it with some cleats can do something, or maybe with an humidifier into the soundhole can correct the waving soundboard ?
Thanks in advance
Posted 2018-02-10 1:37 PM (#541140 - in reply to #541138)
Subject: Re: Ovation 1617 1979/80 great sound but...
I do not know if humidity will cure the "waving"...
But you should humidify the guitar before attacking the crack.
I have a GCXT Flame T that had a big crack in the top when I bought it.
After humidifying it the crack closed-up.
All that I need to do was add a few drops of Crazy Glue from the inside.
So, if the crack is in the wood humidifying it will close the crack somewhat.
Smarter people should be along with better advice.
Aran
Posted 2018-02-10 6:56 PM (#541145 - in reply to #541140)
January 2018
Ok, thanks . I start to humidify inside the soundhole today ,try to see if it works .
Posted 2018-02-10 9:18 PM (#541147 - in reply to #541138)
Welcome to the forum
Humidify
Humidify
Humidify
You can post all over now
Aran
Posted 2018-02-11 5:28 AM (#541153 - in reply to #541147)
January 2018
Thank you !!!
Aran
Posted 2018-02-11 11:05 AM (#541155 - in reply to #541147)
January 2018
Just another thing, can I leave the strings in tension during the process?
Posted 2018-02-11 2:55 PM (#541156 - in reply to #541138)
Sure. You can play it while you are doing it.
Just humidify it in the case when you are not playing it.
Aran
Posted 2018-02-17 5:11 PM (#541265 - in reply to #541156)
January 2018
After one week nothing happened . Crack and waves are still there , maybe it need more times ?
Posted 2018-02-17 6:50 PM (#541266 - in reply to #541138)
You probably have to hydrate more
Aran
Posted 2018-02-18 3:43 AM (#541276 - in reply to #541266)
January 2018
Ok thanks
TAFKAR
Posted 2018-02-19 7:41 PM (#541297 - in reply to #541138)
It's also possible one of the braces has come loose.To check this you will need to take the strings off, or get them loose enough so you can get your hand in the sound hold. It should be possible to wriggle a loose brace - they shouldn't move if you try gently.
Aran
Posted 2018-03-02 12:37 PM (#541448 - in reply to #541297)
January 2018
Thanks ! I've found something inside the soundboard didn't see before (my fault) . Someone , somewhere , put the cleats to close the crack so it will never close again . I think it's better to put a little piece of wood inside the portion that is open , did you think it's a good idea or not?
Aran
Posted 2018-03-02 12:46 PM (#541449 - in reply to #541448)
January 2018
Probably this is the reason why the crack didn't move over the years, as the seller told me
