Posted 2017-10-28 2:38 PM (#537933 - in reply to #537850) Subject: Re: looking for neck for preacher
tadask, email me at mileskb@aol.com and we'll discuss.
There is a nick on the back of the neck that should fill/sand nicely. The mounting holes are there with their inserts but two are covered. It was part of the process to keep the finishing out of the bolt holes. The exposed holes I believe were used to support the neck during finishing.
Posted 2018-04-05 5:09 PM (#543069 - in reply to #537850) Subject: Re: looking for neck for preacher
There is a box down below that states "Attach a file after posting"
If you click that, you can attach a file in the page that appears after you click [Submit]
OR, if you have the photo on another hosting site you can just paste the address of that image and we can go there and look at it.
Posted 2018-04-05 8:15 PM (#543070 - in reply to #543066) Subject: RE: looking for neck for preacher
tadask - 2018-04-05 6:31 AM
but still can't hold in hands neck
Are there any inserts in the preacher neck's holes so screws will fit perfectly?
I'm not understanding what you are saying. The bolts should fit and there are threaded sleeves in the neck already. In the picture above you can see the two exposed ones, and two are covered by the protective dots.
These threaded parts are put in at assembly, from the top, before the fretboard is glued down.
