Location: Steeler Nation, Hudson Valley Contingent | The preamp in my trusty 80s C. Balladeer has passed beyond the pale. I've got a new Op-Pro to put in, and I remember a thread years ago with instructions (and more important for people like me...pictures), but after a couple of wanderings through the search function, I still can't find it. Does anyone remember which one I'm talking about or have some tips? I remember they used modelling clay to mold a template to get the placement right, but that's as far as my middle-aged brain can get. |
Location: Thredbo, NSW, Australia | Patch, I'm in the middle of doing the same to my 1982 Folklore 1614.
Unfortunately I don't have the photos with me, as I'm travelling at present, but I can tell you what I did to get the position for the hole.
I removed the preamp and can from my U681T, placed a sheet of paper on the side and taped it in place after cutting it to fit neatly against the heel of the neck. I then cut a hole in the paper, which was then my template. I removed the sheet and taped it on to the Folklore and marked the hole on the guitar body using a white pen.
I then had a look at some of my other guitars and noticed they weren't all the same. Some were closer to the soundboard than others, and some were a little closer to the head of the guitar than others. This suggests to me that there is some flexibility. You could have a look at your guitars and see which one appears to fit the best and use that to make your template.
I hope this helps. |
Location: Denmark | bvince did it similar: http://www.ovationfanclub.com/megabbs/forums/thread-view.asp?tid=29... . Unfortunately the pics were at the ning site. Whats the trouble with the FET-3? Maybe it can be repaired. It is not overly complicated. http://www.ovationtribute.com/Ovation%20Schematics/Ovation_FET-3_Pr... Maybe a capacitor swap is enough.
Edited by tpa 2017-01-28 5:47 AM
Location: Utah | I'd get a piece of aluminum or tin to use as a template. Bend it to the curve of the preamp can and cut the hole in it. When the can fits properly and the template fits flush against the curve of the guitar body, it should identify the correct placement of the can.
That's a nerve wracking mod. |
| You might want to invest $18 in an oscillating multi-tool from Harbor Freight. In my experience it's the perfect tool for plunge-cutting holes like you'll need. I used one in re-building a traditional wood/canvas canoe and found it very easy to control in making some very precise cuts in the course of removing some ribs. You'll also find all sorts of uses for it around the house. I know that HF power tools aren't the best quality but this one is fine for home use:
http://www.harborfreight.com/oscillating-multi-tool-62302.html
Location: Germany, where delicious wine is growing (Rheinh) | Hi,
I did it several times with nearly all my "old" guitars.
Everybody, who is interest , drop me a PM with your email address and I'll send you the template.
Bernie |
Location: Denmark | Oh - btw. if anyone has a FET-3 that is out of work and that they want to part with. Don't throw it away, instead consider sending it to me, it could be fun to try to revive one of those. Send me a PM if you have one such. |
Location: Italia, Zianigo di Mirano (Venezia) | bburg - 2017-01-29 6:19 PM
Hi,
Bernie Hi Bernie, I don't know if understand well . You have replaced on your old guitars the old preamp's (rectangular as OP 24) with the OP-PRO type ? |
Location: Steeler Nation, Hudson Valley Contingent | Thanks you guys, and keep talking. I'm paying very close attention and taking notes. |
Location: Thredbo, NSW, Australia | Here's the paper template that I mentioned. The guitar is my Adamas 2081
Here's my Folklore with the two positions marked on to it's side.
I used the one closer to the soundboard. I cut the hole using a Dremel that Enowyd lent to me. Worked well. |
Location: Upper Left USA | I did that to a guitar of Damon's one day that he and Sarah came to visit.
I was in the other room with the Dremel. Those bowls scream something terrible under the knife! |
Location: So Cal | Patch...I sent you a template. Worked great on 12 string. |
Location: Germany, where delicious wine is growing (Rheinh) | Titti, I've tried it as well on the OP24 Series, but I can't position where it fits without having a hole left in the body.
IVe upgraded all my real ones with the stacked potis ...
Bernie |
Location: Germany, where delicious wine is growing (Rheinh) | Nobody wants the original Ovation template? It's for the OP-Pro-Series can and for the output jack with XLR.....
Bernie |
Location: Lake Forest, CA | bburg - 2017-01-31 10:29 AM
Bernie
I'll take one. PM sent.
Dan |
Location: N ATL metro | Yeah, I want the template, me too!
I am a die-hard mic guy, but am considering options. |
Location: Thredbo, NSW, Australia | bburg - 2017-02-01 5:29 AM
Bernie
I'm interested, but what format is it in - PDF? |
Location: Jet City | MWoody - 2017-01-30 7:59 PM I did that to a guitar of Damon's one day that he and Sarah came to visit. I was in the other room with the Dremel. Those bowls scream something terrible under the knife! Yep, this one. It ended up with Alison |
Location: Italia, Zianigo di Mirano (Venezia) | bburg - 2017-01-31 7:29 PM
Bernie .
Edited by titti 2017-02-01 7:00 AM
Location: Italia, Zianigo di Mirano (Venezia) | bburg - 2017-01-31 7:25 PM
Bernie Bernie, Bernie, you can post a picture of one ones with the stacked potis ? Thanks... |
Location: When?? | I can't help much with the conversion project, but I thank BCam for the link to the $18 multi-tool :-) |
Location: Germany, where delicious wine is growing (Rheinh) | BanjoJ - 2017-02-01 1:56 AM
Bernie
Yes, it is! But it is the American format. If you print it 1:1 it is original size and will fit exactely. Othewise the messurement is included, if something will not work out.
Bernie |
Location: Germany, where delicious wine is growing (Rheinh) | Titti, have a look in my Album. I gess you will find pictures, if not let my know, I will send you.
Bernie |
Location: Italia, Zianigo di Mirano (Venezia) | ah, now I remember, great album thanks Bernie |
