Op-Pro stopped working. Can anyone fix it?
Posted 2016-10-20 9:35 AM (#529405)
Subject: Op-Pro stopped working. Can anyone fix it?
The title of the thread kind of lays it out there. I have an Op-Pro that stopped putting out a signal. I have no idea why. The tuner still works, but no signal out at all. I also know it's the unit and not the can as I swapped it into a functioning guitar with the same results.
John Budny kindly replaced it as it was on one of my guitars they re-built, but it seemed like a waste to just pitch it back then, and I have since found a use for it if it can be made to work again. The old OP-24 is going bust on my trusty Custom Balladeer 12-string.
So is anyone here handy with these things? Electronics are not my forte.
Posted 2016-10-20 11:20 AM (#529407 - in reply to #529405)
Subject: Re: Op-Pro stopped working. Can anyone fix it?
Disposable
dnc4eva
Posted 2016-11-28 8:58 PM (#530939 - in reply to #529405)
July 2008
The one I have in my 76 C.L. is giving me connection troubles and I believe it is only 2 yrs old. Not much of a OP -Pro fan
Posted 2016-11-28 10:02 PM (#530940 - in reply to #529405)
Did you Shake it?
Did you Blow into the back of it?
Did you drop it onto the Carpet?
Did you clean the Contact Points?
Did you Slide the Sliders, and Spin the Knob?
Still not working?...
That's all I got!
