2005 Ovation Es Collectors
firefox
Posted 2016-10-05 10:35 AM (#529136)
Subject: 2005 Ovation Es Collectors
April 2005
Any advice on how to get the action lower? The Bridge doesn't leave enough room to lower the saddle without it sitting on the bridge itself.
Thanks
DanSavage
Posted 2016-10-05 11:45 AM (#529138 - in reply to #529136)
Subject: Re: 2005 Ovation Es Collectors
June 2012
Sounds like it's time for a neck reset.
Posted 2016-10-05 2:08 PM (#529140 - in reply to #529136)
That has a bolt on neck, or the LX pocket if I remember.
Posted 2016-10-05 2:52 PM (#529142 - in reply to #529136)
Presumably you've adjusted the truss rod properly and the nut height is ok. Correct?
Mike S.
Posted 2016-10-05 5:21 PM (#529144 - in reply to #529142)
Hi, Everyone,
Is there a shim under the saddle? Your owner's manual may mention this. I usually have my guitar tech remove it. This lowers the action about 1/16th". It could save a whole new neck re-set.
Mike S.
Ottawa, On. CANADA.
Posted 2016-10-05 5:30 PM (#529145 - in reply to #529136)
'05 guitar shouldn't need a neck reset. Can you post pictures? Action at the nut, 6th fret, 12th fret, and the saddle.
It should be a bolt on neck. Perhaps a bolt is loose.
