| I'm looking for circuit breaker info on front of amp. Mine is missing and looking to get a replacement circuit breaker. How many amps is that circuit breaker on front? Where can I find replacement etc. Any help would be much appreciated |
| I have a photo but don't see how to add |
Location: Keepin' It Weird in Portland, OR | Check the box down below that sez "Attach a file after posting"....
Then after you "submit" it will allow you to browse and attach a file.
Or, if you have the photo on a public hosting site like Photobucket you can just post the address here. Be sure that the settings are "public"
Location: The Great Pacific Northwest | I would hope that when you open it up to replace the breaker the rating is on the breaker. All of the Ovation power amps I have (they only had a few amps they used in different configurations, show 1.6 or 1.7 amp under the breaker on the panel. Of course the combo amps with the breaker on front are just a red button. I'm surprised it's that low, and I'd be really surprised if yours were any lower. Baring a definitive answer, I'd start with a 1.7 and if it pops (from load and nothing else being wrong) move up to 2 AMP.
| THANK YOU. I DID HAVE THAT CHECKED, BUT STILL DIDNT GET PROMPT ETC. I'M NEW AND ALL. PROBABLY USER ERROR. |
| THANK YOU. DO I NEED THAT RED BUTTON? I DONT HAVE THE TOP CAP/RED BUTTON PART. NOT SURE WHERE TO GET ONE. |
Location: The Great Pacific Northwest | Doesn't have to be red.. easier to press if it pops, but no... you don't "need" the button. You do need the circuit breaker. And you won't be able to post pictures in the forums until you are a full member. For now the moment they will need to be hosted elsewhere with a link. If you think you'll be sticking around let us know and we'll make a full member so you can post in the main forums where many others can assist. |
| thanks again for the effort. I'll look for something at elec. part store as I don't even have the circuit breaker. |
| MILES-K-BARON....DO YOU KNOW WHERE TO FIND A REPLACEMENT CIRCUIT BREAKER? |
Location: The Great Pacific Northwest | Todd Eroh - 2016-05-24 4:16 PM
Stop yelling, I hear you (All caps is like yelling).
Anyway.. I don't have a specific part number... but you are looking for a
Panel Mount
Push to Reset
117 Volts
1.6 amp (1.8 and 2.0 amp seems to be more common)
http://www.allelectronics.com/
http://www.mouser.com/
http://www.digikey.com/
http://www.mcmelectronics.com/
I found this one. It's close and probably would work.
http://www.digikey.com/product-detail/en/te-connectivity-potter-bru...
They come in 1.5 amp and 2.0 amp. As the original was a 1.6 or 1.8 amp, you could probably get away with a 2 amp.
I would call the above places and talk to someone. None of the websites are all that great to navigate, but at least with the above link you have an idea of what it looks like.
