Location: When?? | Well, I took y'all's advice on not messing with the truss rod.. and all is fine.. thank you.. so here I am again with yet another question as I tip-toe through my genesis of Guitar Physics 101.
The guitar in point is a 35-year-old Custom Balladeer, but I guess my question would apply to all guitars, Ovation or otherwise. Does a heavier gauge string put THAT much more tension load on the bridge than light gauge stings? For most of this CB's life it has had Adamas lights (1818s), and once I ran out of those I switched to D'Addario EXP 16 lights (12-53). I knock on wood when I say this, but for that old of a guitar there is virtually no rise in the top behind the bridge and zero lifting on the bridge itself (occurrences that I understand can be somewhat common in that era and model), so I feel I have lucked out on that.. but.. I really would like to install a set of medium gauge strings and possibly keep that gauge for an extended time. Am I inviting problems?
Advanced thanks for your opinions. | |
Location: Keepin' It Weird in Portland, OR | This is a string tension chart for Martin strings, but the principle is the same for all brands.
https://www.martinguitar.com/strings/acoustic/
You will notice that the tension difference between "Extra Light" and "Light" is about 30 pounds.
Then, between "Light" and "Medium" is about another 20 pounds.
This is why you often need to adjust the Truss Rod when changing string gauges or brands.
There is also a difference between string materials.
This is why I use "Silk-n-Steel" or "Silk-n-Phosphor" on my old (weaker) guitars.
Hope this helps.
Location: When?? | Thanks for the link, Arthur. Yes, very useful info. Based on the Martin chart, I am computing roughly 13% more load between Light and Medium, which I would think to apply pretty much about the same across all brands with the same general string thicknesses. So to go upward to medium I would essentially be hanging, for instance, an extra Thanksgiving turkey on my bridge. I'm thinking..... no. I would not have thought it to be that much more tension and would rather buy somebody's $175 used Celebrity to conduct this experiment in personal gauge preference than to try it on a beloved family member. Thank you again for the info!! Glad I asked!! | |
