Hello
Lloyd
Posted 2016-03-31 7:10 AM (#524307)
Subject: Hello
March 2016
Just joined and looking for advice on my beater restoration. It's a made-in-Korea 1517D with a deep bowl and no cutaway I bought in the eighties after not playing since the sixties. (My previous setup was a Vox through a Fender Bassman. Man, I wish I still had those, lol) Anyway, this one has gotten banged up--some nicks and dents, a nice scratch on the top, the lower ear on the headstock broken off, etc. And it needs a fret job. Too expensive to pay for, so I decided to do the work myself. BTW, I've never worked on an instrument before. Here's where I'm at so far....
-removed the tuners, nut, and piezo system.
-Repaired the headstock with a brad (for support), some Famowood, and black medium viscosity superglue.
-Pulled the frets from the rosewood fingerboard...I was lucky to have only a little chipping.
-Sanded the fretboard down to 12 inch radius. It's laser straight right now...dunno what string tension will do to that. Wishing I had Dan Earlewine's neck jig.
-repaired a split in the front of the bridge.
-Did drop finish repairs with aforementioned superglue.
-Decided to remove the bridge, making it easier to refinish the top, and decided to replace the bridge with either ebony or an exotic wood. Or perhaps and Adamas(?) carved walnut. Had a small amount of tearout in 2 spots, under 1/2 inch diameter each.
QUESTION: Best way to fix this? I'm thinking epoxy filler.
-Scraped and sanded the top smooth. It came out really nice. Wiping with alcohol reveals that it will look brand new with a clear finish, although I haven't decided yet whether to stick with black or do something different.
-I noticed that the binding was sitting on a shelf that was slightly proud, and decided to file/sand the bowl smooth. Sanding goes much much faster for this, btw. I don't know if the bowl is fiberglass or Lyracord, but it is exposed, so I believe I will need to do something special to seal it before finishing.
QUESTION: What's the best way seal the bowl?
-Sanded the neck and did drop-fills to a few dents.
-John Budney at DWDrums is sending me an Ovation decal for the headstock, which will make it much easier to deal with repainting. He said to contact Dan Savage here for advise. You there, Dan?
-I'll be re-fretting using EVO fretwire. It's supposed to be nearly as hard as stainless steel, but much easier on the tools. I haven't done that yet because I've been toying with the idea of replacing the fretboard with a maple one.
Question: Can anybody tell me what the scale is on this guitar? It measures 12 5/8" from the nut to to the 12th fret, which should make it 25 1/4 inches. But the distance from nut to saddle is approximately 25.3 inches. Is this compensation? Or is this a Martin dreadnaught scale of 25.4, 25.33 compensated?
And last step before finishing...since smoothing out the binding/bowl, I'm thinking about replacing the binding and perhaps the purfling as well. I'll have a parts bowl to experiment on soon, as I'm buying that $25 neck and bowl from the same model guitar from Alexander Pepiak at LostArtVintage.
I'm Lloyd and glad to have found this site.
Lloyd
Posted 2016-03-31 9:29 AM (#524311 - in reply to #524307)
Subject: RE: Hello
March 2016
Can I get approved to post to other areas? Thanks.
Posted 2016-03-31 10:31 AM (#524313 - in reply to #524307)
Subject: Re: Hello
Welcome Lloyd
Feel free to post everywhere
