Nut Files
sycamore
Posted 2016-03-12 2:31 AM (#522860)
Subject: Nut Files
March 2007
I've borrowed a set of nut files to do a bit of work on a mandolin (and maybe a few guitars while I'm at it).
the thinnest file is 0.015" whereas the e strings on the mando are 0.011". WIll this file make the slot too wide? The nut is not bad as it is but I want to lower the slots just a fraction to make it just right.
Posted 2016-03-12 1:40 PM (#522873 - in reply to #522860)
Subject: Re: Nut Files
Check out these welding tip files. Might be what you're needin'......
http://www.ebay.com/itm/NEW-Welding-Tip-Cleaner-Carb-Jetting-tool-p...
DanSavage
Posted 2016-03-12 6:42 PM (#522881 - in reply to #522860)
June 2012
I usually try to keep the slots as close to the string width as possible.
If it were mine, I wouldn't use a .015" for a .011" string.
