Is it really a positive in some cases to have bellying on a guitar?
Explorer
Posted 2016-01-09 6:48 PM (#520094)
Subject: Is it really a positive in some cases to have bellying on a guitar?
December 2015
I've talked with a few people whose guitars have major bellying.
They tell me that bellying is designed into the guitar, but I have no idea how a builder could design in a specific amount of bellying, and the changes in string geometry, and to know that the instrument will shift just that much, and no more. .
Could someone shed some light on whether there is some control over the process, assuming that it's actually planned, and how the limits get enforced while it happens?
Or is this some kind of justification, with no factual basis?
Posted 2016-01-10 1:42 PM (#520108 - in reply to #520094)
Subject: Re: Is it really a positive in some cases to have bellying on a guitar?
"Assuming that it's actually planned,".........not. Nobody's crystal ball, or reading of tea leaves, is that good. If you're lucky, it doesn't get so bad, it can't be compensated for.
DanSavage
Posted 2016-01-10 8:00 PM (#520113 - in reply to #520094)
June 2012
What your friend might be referring to is that some guitars, such as Martin, are built a 'bulge' in the soundboard.
While they are called 'flat-top' guitars, most of the time they aren't really flat. Instead they are built with a radius 'bulge'. In the case of Martins, they have a 28' radius 'bulge' built into the soundboard.
Ovation guitars are one of the few, truly flat, 'flat-top' guitars.
To my knowledge, no guitar is designed for instances where the belly will rise to the point where the neck/string geometry is perfect. That's why a lot of manufacturers design the neck joint so that it can be (somewhat) easily removed to allow the neck geometry to be reset to compensate for the bellying that inevitably occurs.
