Resetting the action?
Cripple Rick
Posted 2015-12-18 6:52 PM (#519525)
Subject: Resetting the action?
April 2013
I just picked up a used 1866 Legend 12-string. Looks and sounds wonderful (at the top end of the neck)....but the action is about 1/4" at the 12th fret. And all the shims are missing. What can be done? Thanks.
leonardmccoy
Posted 2015-12-19 1:43 AM (#519537 - in reply to #519525)
Subject: Re: Resetting the action?
December 2015
Is the neck straight?
Cripple Rick
Posted 2015-12-19 8:52 AM (#519548 - in reply to #519525)
April 2013
Yes, the neck looks straight, bridge is flat to the soundboard, and it sounds great when played up to the 5th fret or so.
Posted 2015-12-19 10:54 AM (#519551 - in reply to #519525)
You have to check these with a long straight edge. I like a 2 by 3 feet square. I use the 2 foot side to move around on the frets and see if there is a valley or a mound. Sometimes the 12th fret will be high and the 2 foot side will rock over that fret. The 3 foot side should sit flat on all the frets and line up with the top of the bridge, ideally. If the straight edge sits flat on the frets or the frets are only very slightly mounded (I can never remember which is "bowed" and which is "warped", but the straight edge hits below the top of the bridge, you will need a neck reset. If you use the 3 foot side and it sits on the bridge and the first fret, but sits high above the 12th frets and up, same thing, you need a neck reset.
Cripple Rick
Posted 2015-12-19 11:21 AM (#519555 - in reply to #519525)
April 2013
Thanks for the input Leonard and Mark. Doesn't sound like a cheap fix.
bburg
Posted 2015-12-19 12:07 PM (#519556 - in reply to #519525)
August 2009
Hi, loosen the strings and check whether the neck has come loose to the Body. There is a bolt inside the Body were the neck joins the Body. It's a shallow bowl, so it has only one bolt, all others have two.
I had the same issue on my 5858 Elite and this was the Problem.
Bernie
Cripple Rick
Posted 2015-12-19 12:58 PM (#519557 - in reply to #519525)
April 2013
Thanks, Bernie, I'll check.
