Glue again- rubber to metal
sycamore
Posted 2015-08-24 4:04 AM (#514669)
Subject: Glue again- rubber to metal
March 2007
What to use to glue rubber to metal (nickel-plated brass l think) ? The pad (not the sleeve) of my shubb capo has fallen off. Once I get a suitable piece of rubber, what will hold it in place? The newer shubbs have little holes in the metal with little nubs on the pad but mine is just flat (will try and post a pic). Thought I'd just get a new cape but seems a shame for it to give up after only 25 years' service.
DanSavage
Posted 2015-08-24 9:17 AM (#514673 - in reply to #514669)
Subject: Re: Glue again- rubber to metal
June 2012
Are you asking what glue will hold a strip of rubber to the metal capo and not fail under use?
You could try this stuff.
http://www.acehardware.com/product/http%3A//ace.imageg.net/graphics...
You'll need to scuff the metal up really well to give the silicone a good surface to grab onto.
If this doesn't work, I'd just spend the $20 and buy a new capo.
SOBeach
Posted 2015-08-24 11:57 AM (#514680 - in reply to #514669)
Subject: RE: Glue again- rubber to metal
April 2010
sycamore - ...seems a shame for it to give up after only 25 years' service.
cheese wiz  Ain't nothin' built to last anymore?!
fwiw,  I've had some success with double-sided adhesive tapes.  ymmv
ksdaddy
Posted 2015-08-24 1:46 PM (#514683 - in reply to #514669)
April 2003
You know those blister cards in every store? Back in the late 80s/early 90s I worked in a factory that made golf spikes. In addition, we packaged them for retail sale in those blister cards. I used to make the plywood molds to glue the blisters on, 6 at a time. The cards were coated with a heat release glue and where each blister was located on the board, I had to glue strips of mouse pad-ish rubber to serve as cushioning. The ONLY thing I found that would work is silicone adhesive. Not sealer.....adhesive. I think that stuff will glue anything to anything. Below is a crappy photo of the hand-packaging process as done in 1987 (my late wife on the right):
sycamore
Posted 2015-08-25 5:06 AM (#514719 - in reply to #514669)
March 2007
Thanks everyone. Tried a few things. No joy so buying a new Shubb.
