Busted Battery Box
cool66
Posted 2015-05-16 7:03 AM (#510548)
Subject: Busted Battery Box
July 2004
Not wishing to re-invent the wheel, what have you found to be an acceptable and reliable method of reattaching the battery box to the inside of a 1982 era 1669?
Thanks....
cool66
Posted 2015-05-16 7:53 AM (#510550 - in reply to #510548)
Subject: RE: Busted Battery Box
July 2004
Here's what it looks like....
Posted 2015-05-16 7:54 AM (#510551 - in reply to #510548)
Subject: Re: Busted Battery Box
If you are talking about the outside screw version, proper alignment, & remembering the orientation of the tab on the screw. Then loosening the strings, to get your hand inside the critter. Probably obvious, & may not address your dilemma, but you asked.........
cool66
Posted 2015-05-16 8:06 AM (#510552 - in reply to #510548)
July 2004
Again.....
cool66
Posted 2015-05-16 8:15 AM (#510553 - in reply to #510548)
July 2004
Another......
(DSCN4238 (1).jpg)
Attachments DSCN4238 (1).jpg (110KB - 0 downloads)
cool66
Posted 2015-05-16 8:16 AM (#510554 - in reply to #510548)
July 2004
Here.....
(DSCN4239.jpg)
Attachments DSCN4239.jpg (83KB - 0 downloads)
Posted 2015-05-16 11:15 AM (#510555 - in reply to #510548)
There should be a foam piece. Won't stay on there without it. You can probably make something for yourself.
Anyone have a pic to show cool what it's supposed to look like?
Jonmark Stone
Posted 2015-05-16 12:28 PM (#510557 - in reply to #510548)
The foam applies enough pressure to hold the box in place when you twist the screw/lock.
(Batt_box.jpg)
Attachments Batt_box.jpg (212KB - 0 downloads)
cool66
Posted 2015-05-16 12:56 PM (#510559 - in reply to #510548)
July 2004
Thanks gang. That foam piece wasn't in the bowl, just that box in the pictures. Strange. However, I did locate some industrial strength velcro out in the garage, found that flat spot by the volume control and stuck it there. The velcro is nice and thick so I don't think there will be any vibrations.
Thanks.....
