WTB - Optima Pre Amp (complete or jacks module only)
EricGagne
Posted 2015-01-17 8:34 AM (#504798)
Subject: WTB - Optima Pre Amp (complete or jacks module only)
October 2013
As title says, I'm looking for an Optima Pre Amp.
Mine works except for the 1/4" plug that makes noise whenever the jack moves so I will buy either a complete preamp or just the connectors module, whichever I can find first.
Posted 2015-01-17 9:40 AM (#504801 - in reply to #504798)
Subject: Re: WTB - Optima Pre Amp (complete or jacks module only)
Have you pulled the jack out and checked the wiring connections? Sometimes the jack gets loose enough to spin in the hole and weaken the solder points.
Or it might just be dirty.
I seriously doubt the preamp is at fault.
EricGagne
Posted 2015-01-17 10:13 AM (#504802 - in reply to #504801)
October 2013
Yes I pulled it out. Actually had a topic about this a while back. The solders are fine, the jack has kind of come soft and the 1/4 plug moves in it and makes some bad sounds.
http://www.ovationfanclub.com/megabbs/forums/thread-view.asp?tid=37...
MatureWolf
Posted 2015-01-17 2:28 PM (#504812 - in reply to #504798)
May 2010
Hi! I have spare XLR module, but it's "newer version":
- designed for OP-50, OP-Pro/Studio
- Diameter of XLR plug hole is 22mm (comparing to 24 mm for Optima's module)
http://www.ovationfanclub.com/megabbs/photos/show-album.asp?albumid=1195&photoid=4987
I tested it with Optima - it works, but I can't provide any warranty.
Please PM if interested
Best, Alex
Edited by MatureWolf 2015-01-17 2:59 PM
tpa
Posted 2015-01-17 3:23 PM (#504815 - in reply to #504798)
If everything else fail, I think this should be a good match: http://dk.rs-online.com/web/p/jack-trs-stik/2104968/ Be sure to get the TRS version RA 49C14B
Edited by tpa 2015-01-17 3:25 PM
