Which fret level tools? File, beam, or radius block?
Posted 2014-05-24 9:51 AM (#487051)
Subject: Which fret level tools? File, beam, or radius block?
Three of my old O's could use some new frets so now is a good time for me to learn a new skill.
After installing new frets, which tool do you recommend for leveling them? What are the relative benefits and downsides to each of the types of tools?
tpa
Posted 2014-05-24 1:46 PM (#487056 - in reply to #487051)
Subject: Re: Which fret level tools? File, beam, or radius block?
I have not done such work (yet) so I have nothing to recommend. BUT with similar plans in mind I sometime ago purchased a fret file from Thomann for trying to recrown frets. This tool I can not recommend. It does not fir any frets on any guitar that I have so it was a waste of good money. Stay away from that.
The basic tasks of dressing frets etc. are well described here: http://www.fretnotguitarrepair.com/repair/acoustic-guitar/fret-leve...
Posted 2014-05-24 3:00 PM (#487059 - in reply to #487051)
Thanks TPA. I have a short file from Stew-Mac which works well for filing just one fret at a time. Their fret crowning file also works well.
Posted 2014-05-27 7:54 PM (#487171 - in reply to #487051)
I hate to make an unsolicited plug, but bite the bullet, & buy the basic StewMac fretting kit. A bit spendy, perhaps, but you get great tools, & great tech support. You've got 3 guitars. The last one will be perfect. Then, do the first one, over again.
Posted 2014-05-27 8:06 PM (#487172 - in reply to #487051)
I've started ordering stuff from StewMac. One order per paycheck, should have everything I need in 4 more weeks. I still haven't decided which leveling tool to get. Most everything is coming from S-M except the fret end bevel file. Fret wire I will wait and see what the slot dimensions are after pulling some frets.
The first project will probably be my first real guitar, a 1969-ish Yamaha. It is pretty well worn and needs a neck reset too. So some flubbed frets won't matter.
Then there's a Breadwinner, Viper, and Patriot in need of new frets. All are great guitars. The Patriot is bar none the very best sounding Ovation or Adamas I've ever played, including famed original slothead #43.
ksdaddy
Posted 2014-05-27 8:32 PM (#487174 - in reply to #487051)
April 2003
I've been very lucky in that I take plenty of time leveling the board itself and I can't remember the last time I had to level the new frets. If I am leveling old frets I use a hardware store flat file to kiss the high spots and then a diamond fret file to recrown. Then I hold bits of progressively finer paper in the concave face of the diamond file, then steel wool, then aggressive buffing. I spend more time rounding the ends than anything else.
