Hercules wall hangers
Posted 2008-02-04 1:52 PM (#56719)
Subject: Hercules wall hangers
I bought a Hercules wall hanger.
It will work fine for the Breadwinner but won't I need a longer shank (Dave.... don't go there) to hang a deep bowl?
Posted 2008-02-04 2:02 PM (#56720 - in reply to #56719)
Subject: Re: Hercules wall hangers
Is there no end to your extravagance?
Posted 2008-02-04 2:03 PM (#56721 - in reply to #56719)
Nope, that one should work fine. You just gotta turn the wood around 90 degrees from the picture tho.....
Posted 2008-02-04 2:03 PM (#56722 - in reply to #56719)
Is there no end to your extravagance? First airlocks, now a wallhanger....
Posted 2008-02-04 2:04 PM (#56723 - in reply to #56719)
I have no idea what happened there.
Posted 2008-02-04 3:16 PM (#56724 - in reply to #56719)
A shiny coin on the floor?
Posted 2008-02-04 3:35 PM (#56725 - in reply to #56719)
Listen to "The Old Trader" :D
maxdaddy7271
Posted 2008-02-04 5:37 PM (#56726 - in reply to #56719)
March 2006
...with some degree of uncertainty.
Posted 2008-02-04 5:40 PM (#56727 - in reply to #56719)
They fit deep bowls just fine...
Posted 2008-02-04 5:54 PM (#56728 - in reply to #56719)
Though you might want to put a small pad on the wall to cushion where the bowl will contact it.
Posted 2008-02-04 5:55 PM (#56729 - in reply to #56719)
...did somebody say "shiny coin"...?
Posted 2008-02-04 6:02 PM (#56730 - in reply to #56719)
and look!... another over there....
Posted 2008-02-04 6:30 PM (#56731 - in reply to #56719)
Would that be to protect the wall?? :D
Posted 2008-02-04 6:43 PM (#56732 - in reply to #56719)
They all work fine. Even the shop-built units.
Posted 2008-02-04 6:44 PM (#56733 - in reply to #56719)
Yeah. Sure ain't gonna hurt the bowl. Just to keep it from leaving a scuff mark on the wall.
Posted 2008-02-04 7:16 PM (#56734 - in reply to #56719)
Buy the ones that pivot at angles and hang out further from the wall. That way if you're anal about your guitar hitting the wall, you can feel safer. But the real value of these is that you can hang more guitars in a limited space. Basically 3 in the space of 2. That means they are a real bargain. Buying more guitars to fill up the space is way better than buying a bigger house to hold the guitars. The worst scenario would be having to sell guitars because you ran out of room.
Posted 2008-02-04 7:27 PM (#56735 - in reply to #56719)
Thanks for the advise guys.
And Mark... I like your way of thinkin'!
I should have some photos is a few days.
Posted 2008-02-04 7:45 PM (#56736 - in reply to #56719)
Mine are the same as your picture and the bowl doesn't even come close to hitting the wall. My 1681 has about 2 inches of clearance from the wall. Make sure you look on the back of the wood and mount them as instructed (arrow up) DUH....
Posted 2008-02-04 7:45 PM (#56737 - in reply to #56719)
And Schroeder...
If I may borrow a phrase...
bite me.
Now... where did I leave those air-locks?
G8r
Posted 2008-02-04 7:52 PM (#56738 - in reply to #56719)
I have 3 Hercules wall hangers and 2 String Swing hangers. I definitely prefer the Hercules.
For the Hercules hangers I cut a piece of 3/4 oak to a 4X5-1/2" rectangle and routed an Ogee on the edges, then drilled countersunk mounting holes positioned so they'd be under the Hercules mounting block. The blocks that I cut and stained I then mounted with tapcons into our concrete block walls, and finally used self-tapping wood screws (with a pilot hole in the underlying block) to mount the Hercules mounting block to that. My deep bowls wind up being about 2-1/2" away from the wall.
The String Swing wall hangers don't come with a mounting block like the Hercules. I made a similar mounting block for those (just single thickness, 3/4") and with those the deep bowl winds up just about 1" from the wall, and the wood-boxes about 2".
Posted 2008-02-04 8:03 PM (#56739 - in reply to #56719)
You can get either brand with or without the mounting blocks. I bought them without. Instead of oak, I used mahogany, just because I had it laying around. I mounted the finished mahogany boards to the wall using deck screws into the studs. That way I don't have to trust the sheetrock hangers that come with them. Then I just use the supplied screws and mount the hangers to the mahogany. I have 3 Hercules and 9 String Swings. I trust the String Swings more. They seem sturdier and the mounting screws didn't snap off like one of the Hercs did.
Brad, a disclaimer should go with any of my arguments: Don't try them at home. They sound really good to me, but my judge and jury doesn't find them persuasive.
Posted 2008-02-04 9:52 PM (#56740 - in reply to #56719)
"and look!... another over there...."
...WHERE ALREADY...?!?!?! You're KILLIN' me, MAN!!!
worshipleader
Posted 2008-02-04 11:14 PM (#56741 - in reply to #56719)
June 2004
I'm with Jim. I have two deep bowls hanging on "the wall" - no probs - at least two inches clearance.
Posted 2008-02-05 9:25 AM (#56742 - in reply to #56719)
I use the "OffTheWall" hangers myself, but I also use these little .25" dia. pressure-sensitive, clear silicone "bumps" on the wall.
Y'stick one where the bowl might "likely" touch the wall (being clear, they're virtually invisible).
If by chance the guitar were to swing "back" on the hanger, it EVER-so-slightly "bonks" back . . .
Posted 2008-02-05 9:50 AM (#56743 - in reply to #56719)
I think I'm up to 40 wall hangers of various sorts. I've got them on walls, dropped from ceilings using an angle bracket, attached to metal racks, on a brick fireplace, sticking out the side of an amp, etc. I even have a few cheapies that are nothing more than a 1/4" lag welded to a piece of steel bent into U shape, then covered in foam. They all work just fine as long as the attachment is secure. Depending on the mount, the deep bowls are the most likely to rest against the surface, and that is an easy issue to resolve with a little protective material as Cliff suggests.
Posted 2008-02-05 10:13 AM (#56744 - in reply to #56719)
. . . plus, the little "bonk" sound is really cool . . .
Posted 2008-02-05 10:50 AM (#56745 - in reply to #56719)
I've got the string swings, I didn't use mounting blocks, and they do touch the wall.
However, (one of) my upcoming projects is to replace them with a piece of oak with 6 of the Herc angle hangers so I can make better use of the limited wall space I have.
btw, one of the cool things about having a bunch of guitars hanging on the walls of a small room is when you sneeze.
Posted 2008-02-05 11:55 AM (#56746 - in reply to #56719)
You are weird Wabbit. I noticed the same thing. I like to see which rings the longest after I sneeze.
Posted 2008-02-05 12:26 PM (#56747 - in reply to #56719)
Mark,
You're not far behind. :confused:
Which one does ring the longest? :D
Brian T
Posted 2008-02-05 12:34 PM (#56748 - in reply to #56719)
..Remind me to wipe it down first if you ever let me play one of your guitars!
Posted 2008-02-05 1:16 PM (#56749 - in reply to #56719)
I try not to sneeze in the direction of the guitars, but I have noticed that the TV screen is getting a little cloudy. Brian, I'll wipe them all down special for you. I have those stools waiting for you and Brad anytime. Tell him that my favorite little ski hill already passed 300 inches of snow this year and the weather forcast keeps showing a picture of a skier in powder so deep all you can see is his gloves.
Back to the sneeze thing, I can't tell which has the most sustain. It seems to be the Ute or the OFC, but they are too close together.
Posted 2008-02-05 1:27 PM (#56750 - in reply to #56719)
6758 definitely rings the longest (12 string), followed by the 1581.
Brian, you don't have to sneeze on the acoustics. You do have to get pretty close to get a response out of the Viper, though.
Be careful visiting Mark. You should always be cautious when someone tells you they have 'stools' waiting for you...
Posted 2008-02-05 1:41 PM (#56751 - in reply to #56719)
Man the wealth of information one can find on this forum is beyond description. :confused:
