strings
stuart
Posted 2008-02-26 11:35 AM (#52879)
Subject: strings
January 2008
hi there silly question but would like a bit of feed back what make and gauge of strings are good for finger picking thanx
Posted 2008-02-26 11:39 AM (#52880 - in reply to #52879)
Subject: Re: strings
lite
brainslag
Posted 2008-02-26 11:40 AM (#52881 - in reply to #52879)
Long thin metal ones.
Posted 2008-02-26 12:27 PM (#52882 - in reply to #52879)
Day-um, maybe that's been my problem! :eek:
Posted 2008-02-26 12:55 PM (#52883 - in reply to #52879)
Most any string will sound good on an Ovation. The trick is to always use string tubes. :cool:
I use D'Addario Custom Lights,(.011-.052).
Posted 2008-02-26 2:50 PM (#52884 - in reply to #52879)
I do the lights for fingerpicking. .012 is the thinnest and they usually run to .053 or .054, depending on the brand. I usually use Adamas, but also D'Addario or I've been liking the Martin Eric Claptons on my Folklore and have a set that I'm going to try on something else. I have so many guitars that need string changes, I can't make up my mind which to do first.
Posted 2008-02-26 3:04 PM (#52885 - in reply to #52879)
Mediums.
Posted 2008-02-26 3:13 PM (#52886 - in reply to #52879)
medium lights
Paulcc1
Posted 2008-02-26 3:17 PM (#52887 - in reply to #52879)
September 2004
John Pearse lights 600L
scott lamperd
Posted 2008-02-26 3:39 PM (#52888 - in reply to #52879)
Custom light 11-52 if you have a soft touch, 12-53 for a little more punch. Elixers are my favorite.
Scott
G8r
Posted 2008-02-26 4:11 PM (#52889 - in reply to #52879)
Lights (12-53/54). Was using D'Adds EXP and Adamas interchangeably, but started using Martin SP phosphor bronze - not as "brassy" sounding & less squeak. Last almost as long as the long-life D'Add EXP at about 1/3 the cost. Tried Elixirs & couldn't get used them sounding dead when new, then sounding better after a couple hours of use. Gonna try DR Blue Peacocks on my Tak next string change.
stuart
Posted 2008-02-27 1:36 AM (#52890 - in reply to #52879)
January 2008
thanx for advice will try some medium and lights just dont like the squeak playing dust in the wind at the moment one of my favorites and its played on a ovation naturally..
