High bridge on CC48
JRinAZ&MN
Posted 2013-04-02 11:44 AM (#469112)
Subject: High bridge on CC48
March 2013
I just bought a new CC48 and have a problem with it. The bridge is too high. I took out the only two thin shims underneath the pickup but I still have .025 of excess height. I noticed that this CC48 (I have another CC48 in Minnesota) has a different bridge with individual "steps" for each string, making milling it down difficult.. Has anyone else had a similar problem?
Thanks,
Jim
TAFKAR
Posted 2013-04-02 6:04 PM (#469129 - in reply to #469112)
Subject: Re: High bridge on CC48
Next thing to check is whether the neck is straight. The easy way is to sight down the strings and see if the next is bowed upwards. If so, a 1/4 turn of the truss rod (located inside the bowl) should fix that. For more info on how to do this, search these forums.
JRinAZ&MN
Posted 2013-04-02 6:18 PM (#469131 - in reply to #469112)
March 2013
Neck is straight... It's just made with too much height.
JR
Posted 2013-04-02 6:24 PM (#469132 - in reply to #469112)
Did you buy it NEW new? If possible, return it.
You should not have to go through a bunch of crap with a New guitar.
JRinAZ&MN
Posted 2013-04-08 1:03 PM (#469354 - in reply to #469112)
March 2013
I cAn't send it back for a refund, so I'm left with repairing it. I emailed Ovation customer support and they told me to order the replacement bridge part. I guess I'll order it and have it trimmed down.
TAFKAR
Posted 2013-04-08 8:18 PM (#469378 - in reply to #469112)
If you search the archives here, someone once took a router to the saddle groove as a way of lowering the saddle height. You'd want to be very confident in your ability though.
JRinAZ&MN
Posted 2013-04-10 6:10 PM (#469442 - in reply to #469378)
March 2013
A router sounds a bit "over the top", to me, the solution is to machine the bridge insert down a bit. I'll order a replacement and since I have a "machinist friend", have him take the desired distance off the bottom of the insert... It seems a shame, since it's new...
But you look at things, it's the first "lame" Ovation in several that I've owned, and (some) still wished I had...
JR
JRinAZ&MN
Posted 2013-04-14 9:55 PM (#469576 - in reply to #469112)
March 2013
I guess I'm going to the acoustic guitar forum, where I can post and really get onto the forum... This is lame where you can only post in the the welcome section..
JR
Posted 2013-04-15 7:45 PM (#469592 - in reply to #469112)
JR, lame as it is, we try to keep bots and spammers out.
Feel free to post in the main sections.
JRinAZ&MN
Posted 2013-04-16 6:40 AM (#469598 - in reply to #469112)
March 2013
Thanks,
JR
