more pics (broken case and Op Pro Studio)
MeredithI
Posted 2013-03-31 2:54 PM (#469051)
Subject: more pics (broken case and Op Pro Studio)
November 2012
Thanks to muzza I have figured out how to upload photos, although they may end up very big.  Sorry about that.  I'm practicing.  Here is the case that came with my Custom Elite 2078 LX.  The guy who sold it to me said the bottom of the case had the crack when he bought it from someone else.  I wonder if this will effect the safety of the guitar inside.  Should I consider a new case?  Recommendations?  And see the bottom photo too.  Somebody help me with this thing please.  Apparently it needs a battery, but I don't know how to replace it.
Oh yeah, and how do I replace the battery in this??  I have no idea who to use it and I can't find anything online that resembles a "user's manual."
BanjoJ
Posted 2013-03-31 3:32 PM (#469052 - in reply to #469051)
Subject: Re: more pics (broken case and Op Pro Studio)
September 2012
To access the battery you press the release button, which is the big button at the end near the tune button. The pre-amp will pop up a bit, and you can then remove it. They can be a bit tricky to get started.
The battery is at the back of the unit.
Take care when you reinsert the pre-amp. Make sure you line it up carefully before pushing it home. Insert the wide end first to engage its keepers before pushing in the narrow end.
Nice guitar! I have the 1997 model - love it!
jay
Posted 2013-03-31 3:35 PM (#469053 - in reply to #469051)
Subject: RE: more pics (broken case and Op Pro Studio)
January 2009
May not be the same Pre Amp, but close enough so you should get the general "iDea" (I'm here all week) right HERE
Edited by jay 2013-03-31 3:36 PM
Posted 2013-03-31 8:57 PM (#469059 - in reply to #469051)
Meredith, you need to re-size you photos and preview before posting.
Really large photos make the whole thread hard to read.
And be careful when putting the preamp back in...
Make sure that the right side goes in first.
MeredithI
Posted 2013-03-31 9:26 PM (#469060 - in reply to #469051)
November 2012
Resizing photos is apparently tricky. It took about 3 tries to get these photos below 200 KB so they would upload. I use Adobe Photoshop Elements. I can vary the pixels/inch (resolution) as well as the physical size in either pixels or inches. I need to find the "magic formula" to get it right.
Thanks for the tip on getting the preamp in and out.
Posted 2013-03-31 9:41 PM (#469061 - in reply to #469051)
72 ppi and 700 pix wide should work fine
muzza
Posted 2013-03-31 10:21 PM (#469064 - in reply to #469051)
August 2005
As I told you, ignore the filesize [ie "200kB"] and edit the photo's physical dimensions, like Standingovation recommends; 72 pixels per inch (ppi - sometimes called dpi - dots per inch) 600 -> 800 pixels wide, depending on how detailed you need the photo to be. Up to 1000 pixels wide is bearable on most modern computers if you need to show something accurately in context, but 700 wide is a good starting point.
I think TAFKAR has the record for the largest photo posted, (I think it was something like 450,000 pixels wide) so don't feel TOO bad...
Edited by muzza 2013-03-31 10:23 PM
SOBeach
Posted 2013-03-31 10:57 PM (#469065 - in reply to #469051)
April 2010
You're not alone Meredith, lots of folks find this picture uploading stuff a bit bewildering, especially if ya don't have a teenager around (who of course knows everything) to show ya how "simple" it is!
muzza
Posted 2013-04-01 1:50 AM (#469067 - in reply to #469051)
August 2005
It IS simple!
MeredithI
Posted 2013-04-01 3:32 AM (#469068 - in reply to #469051)
November 2012
Muzza is our resident "teenager" then. In my house I am the "teenager." My husband only knows the basics. The rest he leaves to me. He doesn't have a clue how to format a graphic. I have done publishing, music notation, presentations, all with technology. I don't know everything, but I'm no slouch.
DanSavage
Posted 2013-04-01 12:42 PM (#469076 - in reply to #469051)
June 2012
Meredith,
You don't have to use photoshop to resize (resample) your image size.
When you post an image using the insert/edit image box, one of the options is dimensions.
Normally, this will be automatically filled when you enter the image URL.
If the size is wider than 800, then manually enter the size you want.
For example, the actual image size below is 1024 x 768.
But, I forced it to be 320 x 240 by editing the image dimensions.
This can be done when creating a new post, or by editing the post, then clicking on the image and adjusting the size.
Dan
AstroDan
Posted 2013-04-01 3:45 PM (#469082 - in reply to #469060)
March 2010
MeredithI - 2013-03-31 9:26 PM Resizing photos is apparently tricky. It took about 3 tries to get these photos below 200 KB so they would upload. I use Adobe Photoshop Elements. I can vary the pixels/inch (resolution) as well as the physical size in either pixels or inches. I need to find the "magic formula" to get it right. Thanks for the tip on getting the preamp in and out.
I use PS Elements a lot.
With image open, go to image - image size
then enter 800 x 600 in the pixel dimension set (make sure the maintain image constraints box is checked)
Save as new file.
Makes perfect sized for posting:
edit*** Nice git, BTW!
Edited by AstroDan 2013-04-01 3:47 PM
SOBeach
Posted 2013-04-01 5:00 PM (#469083 - in reply to #469051)
April 2010
Meredith, that case crack doesn't look that bad (I've seen worse). Did you ask the MS tech what (if any) patch method they'd recommend?
I saw in the archives a post from seesquare, stating that Bondo worked "great" for case repairs and (eek) bowls too.  Places like AutoZone, Discount Auto Parts and Sears automotive sell Bondo kits.  I don't know if it'd be strong enough for remounting the case footpad to the same spot though. ??  Any case repair gurus out there?
