Looking for Eclipse neck
pphantom538
Posted 2013-03-27 12:25 AM (#468909)
Subject: Looking for Eclipse neck
March 2013
Hello
I am new to the OFC but had a balladeer since the late 80's . The Balladeer was borrowed by my son back in the 90's so he could learn. He's now 31 and its his favorite when playing live. then 12
I know he'll return it any day!,,,
I decided I wanted to get into some smooth jazz and saw an Eclipse. Love the look.
There is one available which as a repaired neck. Plays well.
I am hoping to track down a replacement.
The other storm series hard bodies appear to be the same specs. Are they interchangeable?
I believe not as the eclipse neck is black and I'm not sure if the others are the same.
Does anyone have one or know where I can find one.
Would appreciate the help.
Regards,
Paul
Posted 2013-03-27 4:22 PM (#468921 - in reply to #468909)
Subject: Re: Looking for Eclipse neck
The eclipse and other storm necks are the same-ish. The main difference is the mounting depending on age. Does yours mount with bolts or screws?
pphantom538
Posted 2013-03-27 6:27 PM (#468926 - in reply to #468909)
Subject: RE: Looking for Eclipse neck
March 2013
I'll check how it's mounted and post.
Thanks
pphantom538
Posted 2013-03-27 8:34 PM (#468931 - in reply to #468909)
March 2013
The neck attached with screws. On another note, I found a solution. Thank you for the help.
pphantom538
Posted 2013-03-27 8:57 PM (#468932 - in reply to #468909)
March 2013
BTW _ I do need a pickguard for the guitar or the pattern from an existing one which I'll use to have one made up.
Posted 2013-03-28 5:54 PM (#468947 - in reply to #468909)
There are a couple different pickguards depending on the year
pphantom538
Posted 2013-03-28 9:26 PM (#468950 - in reply to #468909)
March 2013
Thank you. I have a close photo of the original. Guess I'll have to fabricate one and hope for the best.
Posted 2013-03-29 12:17 AM (#468954 - in reply to #468909)
There are others on the board here that have done them before. Try posting in the main general section, or even in the BFLG section. There are only a handful of people that can respond to posts in the newbie section here.
