Op PreAmp Templates
PaulUK
Posted 2008-03-07 3:21 AM (#51050)
Subject: Op PreAmp Templates
November 2007
Hi
Can anyone help with cutting templates for retro fitting of Op PreAmps?
Bit reluctant to put the saw to the bowl relying on my own home grown one.
Paul
Beggin
Posted 2008-03-07 7:52 AM (#51051 - in reply to #51050)
Subject: Re: Op PreAmp Templates
I think that Dr. CrimsonLake has done this before. He is probably in surgery this morning, but wait a while and he will show up.
Posted 2008-03-07 8:57 AM (#51052 - in reply to #51050)
Paul - I have done this before on two guitars. I made a template out of modeling clay using a guitar that already had the OpPro installed:
Having the properly contoured template allowed me to find the right location to cut the hole. I used a combination of a roto-zip and sandpaper. Once you have the rough hole cut, it's pretty easy to shape with sandpaper - or a dremel with a sanding bit.
Here's a pic of the finished job (this was for another member on the board):
Does the one that you're installing come with both 1/4" and XLR outputs? If so, you'll probably need a template for the output jacks as well. I made that out of cardboard from the output circuit board itself. I don't have a picture of that one though.
This one already had a 1/4" jack, so the location was easy. If yours doesn't, you could put it anywhere you like as long as it's relatively flat.
PaulUK
Posted 2008-03-07 9:17 AM (#51053 - in reply to #51050)
November 2007
That looks interesting! Yes, I do have a guitar with one fitted. Never thought of working from that, doh. I let the clay harden,remove any that has strayed into the hole and then mark out on the new one. Straight forward enough. lead me to the craft shop and a lump of clay. Fitting to a Folklore with early electrics fitted so jack alreay there but as you say will need cutting fo r the XL. I should be able to use the existing pietzo?
Thanks
Posted 2008-03-07 9:56 AM (#51054 - in reply to #51050)
Paul - exactly! Not sure about the existing piezo. The two that I've done came with new pickups. If the jack is the same size, it should work.
Good luck!
Mike
PaulUK
Posted 2008-03-07 10:06 AM (#51055 - in reply to #51050)
November 2007
Thanks again, Mike
1 do have a new piezo, just being a bit lazy!
Paul
Posted 2008-03-07 12:02 PM (#51056 - in reply to #51050)
I had to replace a preamp on a Celeb with an oversize unit. I made a cardboard template. Didn't think of the 'play dough' option.
I used a Dremel with the thin cut-off wheel. Very precise control.
Due to contour, one end of the preamp missed being seated by 1/32". I had a piece of adhesive backed 1/16' black foam gasket that was a perfect match.
Posted 2008-03-07 12:38 PM (#51057 - in reply to #51050)
This is an interesting read. I'm not all that handy with tools and have no doubt that while cutting and sanding the hole in the side of the guitar, somehow, I'd get a nick in the top of the headstock.....
Posted 2008-03-07 2:28 PM (#51058 - in reply to #51050)
I'd nick something that would bleed.
PaulUK
Posted 2008-03-10 7:06 AM (#51059 - in reply to #51050)
November 2007
All very halpfull. Thanks
I have bought the "clay" and will attempt the template at the weekend. Have the Dremel and cutter and have already fit several in timber bodies so here goes....
Will let you know how I progress.
Paul
Has anyone checked my website?
ovationuk.co.uk
