Wider nut
Oldboots
Posted 2012-05-22 4:16 PM (#454851)
Subject: Wider nut
May 2012
Location: Lion hearts country, down by the sea. Bournemouth
Hi Guys,
I am looking to move on from my applause and would like to keep with Ovation, however I would like a model witha wider nut.
So which models have wider nuts please???
Cheers
Oldboots
Posted 2012-05-22 4:38 PM (#454852 - in reply to #454851)
Subject: Re: Wider nut
Assuming you want to stay with steel strings, the Folklore is the standard model with a wider nut. It was previously called the Josh White and you might find a fairly recent Josh White reissue out there.
Oldboots
Posted 2012-05-23 12:30 AM (#454861 - in reply to #454851)
Subject: RE: Wider nut
May 2012
Thanks for the reply, yes I would like to stay with steel strings.
So the Folklore is a blast from the past. Is there anything on Ovations current line up that would be easyer to track down??
Or do Iputa wanted add out!?
Oldboots
Nordicnorm
Posted 2012-05-23 12:56 AM (#454864 - in reply to #454851)
May 2010
The early Folklore has a 1-7/8" nut width. I believe they took us into the '80s. Later models are 1-3/4" at the nut. That is about the same as playing two frets up (capo) on a standard 1-11/16" neck.
Good luck with the search.
Posted 2012-05-23 1:01 AM (#454865 - in reply to #454851)
Might help if we knew your price range.....
08 Collectors
FUD
Josh White
'97 Collectors WN version
a few other limited run ones that Al made special for OFC members
probably a few more
Darkbar
Posted 2012-05-23 5:28 AM (#454867 - in reply to #454851)
January 2009
2009 Collector's Koa.....hard to find.
Oldboots
Posted 2012-05-23 6:59 AM (#454868 - in reply to #454867)
May 2012
Maybe as an interim fix, get a 12 string and string it for six...................................................wash my mouth out! a solution of sorts till a 6774lx pops up.
As for whats in the kitty.......well lets just say enough for the right guitar.
Oldboots
muzza
Posted 2012-05-23 8:22 AM (#454872 - in reply to #454851)
August 2005
Hold out for an old Folklore. Worth the wait. BIG tone.
Edited by muzza 2012-05-23 8:24 AM
Posted 2012-05-23 9:30 AM (#454874 - in reply to #454864)
Hovard Heimdal - 2012-05-22 10:56 PM The early Folklore has a 1-7/8" nut width. I believe they took us into the '80s. Later models are 1-3/4" at the nut. That is about the same as playing two frets up (capo) on a standard 1-11/16" neck. Good luck with the search.
I'm pretty sure the wider nut went through the 90's too. I think it's only the newer LX models that have the 1 3/4.
Posted 2012-05-24 10:01 AM (#454924 - in reply to #454868)
Oldboots - As for whats in the kitty.......well lets just say enough for the right guitar.
Then either a FUD or an '08 Collectors, hands down.
bburg
Posted 2012-05-24 11:34 AM (#454934 - in reply to #454851)
August 2009
Or an Adamas 1680 or1689
