drilling for an endpin jack
Dave R.
Posted 2012-04-07 11:32 AM (#452925)
Subject: drilling for an endpin jack
April 2012
I was recently given a Ballader, model 1112, dating from about 1979-80. It has no electronics, and I would like to install a soundhole pickup, and an endpin jack. The jack requires a 1/2" hole. Can I simply unscrew the strap button, and (carefull) drill or ream the hole? Or, given the nature of the bowl material, is there a recommended way to do this?
Nick B.
Posted 2012-04-07 12:26 PM (#452926 - in reply to #452925)
Subject: Re: drilling for an endpin jack
December 2009
Hi Dave. First you'll need to remove the threaded insert that the strap button is attached to. If you try to drill it out it can spin. A Dremel tool with a small round grinding stone will work, but go slowly so you don't heat it up too much. You need to be careful anytime you drill into composites as the bit can bite and tear the material rather than cut. They make composite bits just for this purpose, but they're expensive. The endpin jacks I've seen installed in Ovations all had a small spruce block glued on the inside (about 1" x 1 1/2" x 3/8") If it were me and I were attempting to do it with a regular drill bit, I'd remove the existing strap button and insert, glue the block in with epoxy, and then drill it out. That way the block would prevent the bit from digging too deep, too quickly. A Dremel tool with a cutting bit or small sanding drum also works well here. Good luck!
Edited by Nick B. 2012-04-07 12:26 PM
Posted 2012-04-07 12:34 PM (#452928 - in reply to #452925)
Welcome Dave,
I realize you mentioned endpin style, but I would recommend, just doing what Ovation does and install a jack in the bowl in the lower rear of the guitar. Go to a Guitar Center or whatever the local store is and check out the factory placement. You still need to be careful, but you don't have to change the design of the guitar to do it, no blocks, etc..
I've upgraded your access and moved this into the General Posting area so more folks may have ideas for you.
Dave R.
Posted 2012-04-07 2:51 PM (#452937 - in reply to #452928)
April 2012
Thanks for the replies. I like the idea of leaving the existing strap button alone, and installing the jack in the lower side.
clrules
Posted 2017-07-16 9:23 PM (#536786 - in reply to #452925)
Subject: RE: drilling for an endpin jack
September 2005
I have a Baggs Lyric that I am installing on my 1157 Anniversary. The Lyric has the combo endpin jack/preamp. It's pretty long how would that affect installation locations? Either lower bowl or endpin location would be fine. Looking for suggestions.
Posted 2017-07-17 12:04 AM (#536788 - in reply to #452925)
Often it is personal preference.
You can use the endpin location...
Or you can install it a little bit lower on the end of the bowl.
Just below the strap button by a coupla inches.
That way you can still have a secure strap attachment.
I am always concerned about endpin jack strap attachment.
The button "collar" can start to un-thread, and there isn't really a lot of area for the strap loop to grab onto.
Here is an endpin jack that I installed into a 1114 Folklore.
I did not include the "collar" on this one, but you can see the threads sticking though.
I hope that this is helpful.
(Picture 38.jpg)
(Picture 39.jpg)
Attachments Picture 38.jpg (69KB - 0 downloads)
Attachments Picture 39.jpg (68KB - 0 downloads)
clrules
Posted 2017-07-17 3:50 PM (#536795 - in reply to #452925)
September 2005
Thanks! Good pics and advice.
