2778AX (Korea) under saddle routing
mikbrx
Posted 2012-03-31 2:16 PM (#452612)
Subject: 2778AX (Korea) under saddle routing
April 2011
I wanted to lower the action by removing a shim. removed the saddle/pick-up. the bridge routing is not completly clean cut through to the top all the way across. clean to the top under the high e and b but starting at the g the routing is tapered from clean up through the d to low e solid bridge material. under the low e it might be a few 64th thick. question, should the bridge be routed clean through to the top all the way across?
questions and comments gratefully received.
Posted 2012-03-31 5:18 PM (#452621 - in reply to #452612)
Subject: Re: 2778AX (Korea) under saddle routing
I have some US models that are like that.
