Really heavy gauge strings a problem?
Geetarism
Posted 2012-03-02 8:14 PM (#451317)
Subject: Really heavy gauge strings a problem?
February 2012
Could putting a real heavy gauge of string on my elite cause any structural problems? I have done it with all my other guitars but wanted to be sue before I go ahead. Thanks
muzza
Posted 2012-03-02 8:32 PM (#451320 - in reply to #451317)
Subject: Re: Really heavy gauge strings a problem?
August 2005
What do you consider 'heavy gauge'?
13's should be OK. The only structural damage I could foresee is ripping the bridge off. Make sure you never try tuning it to open 'E' though.
Geetarism
Posted 2012-03-03 7:44 PM (#451383 - in reply to #451320)
February 2012
I would likely never use that tuning, don't think I ever have. Is that due to the inc tension? I am thinking about going as heavy as I can to minimize buzzz when I downtune to like drop Bb or drop C.
muzza
Posted 2012-03-04 2:27 AM (#451398 - in reply to #451317)
August 2005
See the other thread about the longneck. If you're tuning DOWN you can go WAY heavier. I assumed you were talking about standard tuning.
Posted 2012-03-04 10:22 AM (#451413 - in reply to #451317)
Mediums tuned to concert pitch should be just fine. There are charts out there on the web which show the total tension of different gauges tuned normally. I bet you could find a tension chart for alternate or down tunings. I think if you are not going over the tension of mediums at concert pitch you would be safe.
One dirty approximation of tension would be to measure the height of the high and low strings above the 8th fret (or thereabouts) with your normal strings at normal pitch. More tension will increase it, less tension will reduce it. Put on the heavier strings and tune them as desired. Remeasure the string height. This won't be a precise method, but as long as the string height is not greater you can have some confidence the tension is not greater.
Geetarism
Posted 2012-03-04 6:27 PM (#451429 - in reply to #451317)
Subject: RE: Really heavy gauge strings a problem?
February 2012
Ok. After I saw a video of how to remove the bridge to change the action I became concerned that it may be "weaker" than a traditional bridge. Probably not, but this is my first ovation and don't want to bust it. It sEems like an ox but just makin sure. Thanks again.
TAFKAR
Posted 2012-03-05 4:14 AM (#451467 - in reply to #451317)
I doubt that the bridge is any weaker than any other bridge. The saddle is the plastic(?) bit that come out - it just sits in the groove and is held in place by the string pressure. The bridge is the wooden bit that the saddle sits in, and it is glued to the soundboard (top). The strings pull on the bridge with great force, which can sometimes cause the glue to fail (or a cracked top to fail) with catastrophic results. But (thankfully) this is a fairly rare occurrence and unlikely to happen with medium strings in standard tuning.
PEZ
Posted 2012-03-06 11:22 AM (#451507 - in reply to #451317)
July 2003
I use 13s on a number of guitars
AdamasW597
Posted 2012-03-08 10:19 AM (#451624 - in reply to #451317)
November 2008
Put heavies on it, but tune it down a half step then capo to the first fret. You get the tone and great tension! That's how Stevie Ray Vaughan did it.
Geetarism
Posted 2012-03-09 8:32 PM (#451704 - in reply to #451624)
February 2012
mymartind35 - 2012-03-08 12:19 PM Put heavies on it, but tune it down a half step then capo to the first fret. You get the tone and great tension! That's how Stevie Ray Vaughan did it.
Wow. Never heard of that. That's awesome! Gonna trythat straightaway! Thanks
