Odd mods?
sypolog
Posted 2009-05-06 10:49 AM (#416893)
Subject: Odd mods?
April 2009
So what lo-cost/no-cost mods have you made to your setup that you think just gives you the killer tone?
(At least in your mind...)
Here's what I swear by: a piece of stout copper wire thru the ball ends.
What do you mean, Ouch?
I think it adds bags more sustain and a little brightness. But then, I would, wouldn't I?
What's your trade secret?
Posted 2009-05-06 10:53 AM (#416894 - in reply to #416893)
Subject: Re: Odd mods?
At the factory we used to use an old string to line them up so they'd look pretty.
Posted 2009-05-06 11:20 AM (#416895 - in reply to #416893)
For Electrics:
- Superglue the Bridge Posts.
- Use rubber tubing in the place of springs on the pickups.
- Use White Glue and Newspaper to bond the neck to the body (Factory Tip)
- cut the Nut groove and use a one piece nut, don't shim, replace!
Acoustics:
- Dunlop Straploc's on everything, always tight and use washers or padding on the strap to keep the attachments from rattling.
- The Saddle/shim/OPP area needs a clean seating.
- Find the right strings for each guitar, player and style, there is no universal best set.
And...
- Have someone else play your guitar! :D
Posted 2009-05-06 11:41 AM (#416896 - in reply to #416893)
For Electrics:
Rubber tubing in place of springs
Planet Wave Locking tuners
Dunlop Straploc's with felt
Posted 2009-05-06 11:45 AM (#416897 - in reply to #416893)
What effect does using rubber tubing instead of springs have on tone?
Posted 2009-05-06 12:32 PM (#416898 - in reply to #416893)
Springs may vibrate or pinch a wire. Less metal is less chance for feedback or ground issues.
Minimal effect but it could add up.
Posted 2009-05-06 1:24 PM (#416899 - in reply to #416893)
String tubes for the acoustics, it helps cut down the amount of wood vibration generated by the moving string.
Gallerinski
Posted 2009-05-06 1:35 PM (#416900 - in reply to #416893)
Busters
Posted 2009-05-06 1:46 PM (#416901 - in reply to #416893)
Lessons. Helps a lot...
Posted 2009-05-06 1:59 PM (#416902 - in reply to #416893)
Bigger, more powerful amps, and plenty of them.
gh1
Posted 2009-05-06 2:57 PM (#416903 - in reply to #416893)
Tuning down a half step.
_____
gh1
Posted 2009-05-06 3:54 PM (#416904 - in reply to #416893)
this is what the felt looks like:
GaryB
Posted 2009-05-06 4:57 PM (#416905 - in reply to #416893)
August 2007
Not really an odd mod, but I've got bone nuts (ouch) and saddles on mine. Certainly good bang for your buck.
Gallerinski
Posted 2009-05-06 6:01 PM (#416906 - in reply to #416893)
Fossil ivory bridge pins
Posted 2009-05-06 6:15 PM (#416907 - in reply to #416893)
Music stand extension wings.
elginacres
Posted 2009-05-06 7:39 PM (#416908 - in reply to #416893)
Phil Keaggy played my guitar once - it sounded much better
Posted 2009-05-07 10:36 AM (#416909 - in reply to #416893)
:D
Posted 2009-05-07 10:54 AM (#416910 - in reply to #416893)
Tweaking the nuts. Getting the nut slots to the correct depth improves intonation a lot, especially for the first 5 frets.
Fresh batteries in the effects pedals, or use a plug in power supply.
Finding the right pick for the guitar. Ultex sound best to me on my acoustics. Gator Grip or Dava for the electric. Thinner for strumming, thicker for single notes. Maybe nobody else notices, but I think that the choice in pick makes a difference in clarity and tone.
Speaker swap on the amp (Eminence Ragin' Cajun). It's much better than the Fender factory speaker. At $65 it was more than nothing, but a lot cheaper than buying a whole new amp.
Getting the pickup height set properly on the electrics make a big difference in quality of tone.
Finally, a couple of beers makes my playing sound a lot better!
Posted 2009-05-07 2:01 PM (#416911 - in reply to #416893)
Finally, a "mod" that I'm capable of performing.
Posted 2009-05-07 10:06 PM (#416912 - in reply to #416893)
And if someone else is buying I'll compliment their playing!
