truss rod - what size wrench?
gravydb
Posted 2009-05-27 1:18 PM (#414089)
Subject: truss rod - what size wrench?
April 2009
Hi everyone,
I have a 1989 Ovation Elite (model 1868), which needs a truss rod adjustment. I'm very comfortable making these adjustments, although this is the first time I've had to adjust an Ovation guitar. I just need to know what size allen wrench is needed (I'm assuming I don't need a special tool?).
I'm grateful for your help. Thanks!
NostrAdamas
Posted 2009-05-27 1:33 PM (#414090 - in reply to #414089)
Subject: Re: truss rod - what size wrench?
October 2004
3/16 long Eklind tool hex wrench.Jeff
gravydb
Posted 2009-05-27 2:03 PM (#414091 - in reply to #414089)
April 2009
Thanks Jeff.
I see conflicting stories... 5mm vs 3/16".
3/16" would make sense, since it is a US made guitar.
Thank you!
Posted 2009-05-27 2:59 PM (#414092 - in reply to #414089)
I would go with the 3/16"...
A 5mm might work, but it probably ain't right.
As a do-it-yerself, shade-tree, use-what-you-got, mechanic I have learnt that you can use metric sockets on ASE bolts, but it ain't a perfect fit. If you round-out that hole you will be sad. :eek: :(
Posted 2009-05-27 3:13 PM (#414093 - in reply to #414089)
The one I have (in the little zip lock bag with "Ovation" printed on it) is 3/16", not 5mm.
Posted 2009-05-27 3:14 PM (#414094 - in reply to #414089)
email John or Kim. They would know.
gravydb
Posted 2009-05-28 8:59 AM (#414095 - in reply to #414089)
April 2009
OK, I can now confirm that it is 3/16", not 5mm. I was able to try a 5mm, and it's too big. (3/16" = 4.7625mm). I'll bet the foreign made O's are 5mm though.
And, I was able to adjust it with a 'normal' everyday allen wrench. No need for anything special. And the guitar now plays like a dream again! I am the original owner of this 20 yr old guitar, and this is the first time I ever had to touch the neck relief. It had lost some bow. I only turned the wrench slightly less than 1/4 turn, and it's fine now!
Thanks everybody for your help.
sycamore
Posted 2009-05-28 10:16 AM (#414096 - in reply to #414089)
March 2007
For what it's worth, my US Applause seems to use a metric one. I don't recall the size but I know I only own metric ones an done of mine fits.
