Location: Battle Creek, MI | I have another project guitar and I want to swap out the op24+ for the optima because it has a tuner. Does anyone know if this can be done without modifications to the guitar. I am working on a S771 ovation balladeer |
Location: closely held secret | Size-wise, they should be the same. My Optima measures about 1/16" longer than my OP-24, but that may just be the trim.
As far as the electronics, I'm not sure. I haven't had reason to pull my Optima, but I would imagine by that time the were using the 1/8" jacks for the pickup connection. Someone else here probably could tell you for sure. |
Location: Warren,Pa. | The Optima preamp fits in the same hole, but you'll have to make an additional hole (plus screw holes) for the XLR jack. Also, if your battery box is mounted with a screw fastener inside the bowl you may want to cut a hole for the external-access battery box that the Optima comes with.
John <>{ |
Location: Florida Central Gulf Coast | Originally posted by bauerhillboy:
you'll have to make an additional hole (plus screw holes) for the XLR jack. Here's a thread with the XLR TEMPLATE with 'thanx' to Charlie Ramon.  |
Location: Battle Creek, MI | Thanks for all your replies. Can someone give me a contact to purchase the optima preamp? Thanks in advance |
Location: Scotland | I've recently swapped out an Op24 for an Optima on an Adamas 11 12-string. It's almost, but not quite a direct replacement, so be warned. I had to open up some holes in the bowl mounting bracket and source some slightly longer bolts to attach the pre to the bracket. Also the Optima uses a centre -ve plug for the battery connection while the older preamps have the battery terminals hard-wired, so you need to get hold of a suitable plug. None of this is a huge problem, but it's a PITA if you're expecting just to swap'em out.
If you don't need the XLR facilty just bolt the entire assembly in place using the 1/4 jack, leaving the XLR output inside the bowl. I did that because I needed the 12 string up and running in a hurry, so I know it works. I'll get around to cutting the extra hole somtime, or maybe never. |
Location: Battle Creek, MI | cool...thanks. My S771 has a separate battery compartment that is right next to the op24+. Sounds like it all should work with a little patience and a few parts. Now I have to find an optima preamp.....so far that has been a bit of a struggle |
Location: Warren,Pa. | If you are willing to pay retail, you could give John or Kim a jingle at Customer Service and see if they have any left.
(I guess we don't give "jingles" anymore. : ( |
It sounds like Arlene has the older OP24+ (the square one with seperate battery - my favorite) not the kidney shaped one.
They swap does involve cutting and its not easy. You have to locate the hole exactly for the can to fit properly. I have seen instructions in here on how to do it. If it were me, it would be on its way to the mother ship for that work. Otherwise, leave it just use a hand held tuner. |
Location: Florida Central Gulf Coast | According to Jerome's Preamp PAGE , it should be OK. |
Location: Battle Creek, MI | Thanks to everyone who helped with my search for answers. I got al's page and ordered the new optima today. Thanks for all your help. |
Location: Battle Creek, MI | Does anyone have a photo of a optima preamp installed in the guitar. If anyone has any photos of the set up that would be great. Also, does that preamp have the battery inside the guitar, or is the battery accessable from the outside. Thanks again |
Location: Battle Creek, MI | I ordered my optima from Al....I am hoping it slips in without much issue. Does anyone know the best way to drill a hole in the back of the ovation for the XLR jack? I mean...I am pretty sure any drill will work...but looking for someone with some experience in such.... |
