dual action truss rod
Posted 2008-04-11 9:02 AM (#45573)
Subject: dual action truss rod
Which end adjusts what?
Details please.
Posted 2008-04-11 9:05 AM (#45574 - in reply to #45573)
Subject: Re: dual action truss rod
Turn one way it goes up, the other down.
Posted 2008-04-11 9:45 AM (#45575 - in reply to #45573)
Bill..
You said earlier that you weren't very good at "subtle".
I think you're sellin' yourself a little short there pal. :)
Posted 2008-04-11 9:53 AM (#45576 - in reply to #45573)
Brad - there's a fine line between 'subtle' and 'obfuscatory'...
Posted 2008-04-11 9:54 AM (#45577 - in reply to #45573)
Concise.....
Phil Wong
Posted 2008-04-11 10:03 AM (#45578 - in reply to #45573)
Beal can you explain how a light switch works?
BT717
Posted 2008-04-11 10:12 AM (#45579 - in reply to #45573)
October 2007
Maybe M.B. can also answer for us the question as to if the light really does go off when you shut the fridge door :D
Posted 2008-04-11 10:43 AM (#45580 - in reply to #45573)
I thought that there was 2 seperate place to make different adjustments.
I guess I'm just a victim of marketing hype... again.
Posted 2008-04-11 10:56 AM (#45581 - in reply to #45573)
I thought the same thing, Brad, I was just too embarassed to admit it ...oops.
Posted 2008-04-11 11:46 AM (#45582 - in reply to #45573)
Most rods are loose or tight. You start with a little tension and flatten from there
These dual start from neutral position and make it all flat. Then adjust from there.
