Flying with an O: advice?
dobro
Posted 2009-06-19 1:37 PM (#411247)
Subject: Flying with an O: advice?
Those of you who have taken an O or Adamas with on a flight: is there a SOFT case that can "carry on"? Can it be done with any degree of confidence? I imagine many will say: "Don't!"
For the record: I lugged my Legend around Europe for a year in the mid 80s. Got lucky I guess...
Posted 2009-06-19 1:42 PM (#411248 - in reply to #411247)
Subject: Re: Flying with an O: advice?
I carried on my hard case many times. Put it up in the overheads. I would worry about using a soft case in the event they MAKE you gate check it into the hold, which sometimes happens if the plane is a "regional jet".
Posted 2009-06-19 1:57 PM (#411249 - in reply to #411247)
I have only rarely had to check my hardshell case. Most of the time, if you can get it to the gate (which is most of the time), you'll get it on the plane.
The worst case scenario if you can get it to the gate is that they'll hand carry it on from the gate and get it back to you at the next gate.
I think out of the last 15 times I've flown, I've had to check my guitar once from the ticket counter and maybe twice, it's been hand carried on.
The best was when I was allowed to pre board to ensure the guitar was going to have a spot on the plane.....
Posted 2009-06-19 1:59 PM (#411250 - in reply to #411247)
When flying with a guitar the flight crew are your friends. Treat them NICE.
Nobody else can make you give it up. They will try to. The ticket counter will want you to check it - say no, I'll carry it to the gate. The gate crew will want you to gate check it, I've even been told the flight crew insists on it - say no, I'll ask them.
Once at the door, VERY politely explain that your guitar is precious to you - may you please put it in an overhead?
I've found this will most often get you great cooperation. The last time I flew with a guitar (bringing the Koala back from AI) both the ticket and gate crew got very upset with me because I insisted on asking the flight crew. The flight crew told me, "Sorry, the flight is full, so the overheads are going to be full." Then they proceeded to totally empty the 1st class closet and repack it so they could make room for the guitar. It rode home in more comfort than I did.
Posted 2009-06-19 2:52 PM (#411251 - in reply to #411247)
I've been refused bring it on the plane in Asia, so I wind up gate checking it. Haven't had a problem thank goodness.
Posted 2009-06-19 3:43 PM (#411252 - in reply to #411247)
Sure, the flight crew can refuse it for whatever reason. I've had it happen.
I'm just saying a little sucking up can go a long way towards keeping your precious baby inside the heated, pressurized portion of the aluminum tube.
Bill C
Posted 2009-06-19 3:50 PM (#411253 - in reply to #411247)
I've travelled with electrics in soft cases and acoustics in hard cases, all as carry-ons. With Southwest I've never had a problem--but I fly enough I am almost always a Group A boarder, so I can find a bin space. I've seen folks try to board late group B or Group C with a guitar and they haven't had room, so they had to check it (eek!!!) With soft cases, my main concern is the moron that tries to shove their giant oversize rollaway into the bin...
Dale Lutes
Posted 2009-06-19 3:52 PM (#411254 - in reply to #411247)
March 2008
It seems to me that with most airlines charging additional fees for checked baggage, more passengers are carrying stuff on board, thus filling the overheads to capacity. Last flight I took, I had no choice but to stow my laptop and CPAP under the seat in front of me, leaving absolutely no foot room. No way a guitar would have fit under there. I've never tried checking one at the gate.
Posted 2009-06-19 4:01 PM (#411255 - in reply to #411247)
The one positive about gate checking (if you're forced to) is that they're usually the last in the luggage hold and the first out.
dobro
Posted 2009-06-19 5:21 PM (#411256 - in reply to #411247)
Good advice and important details to consider. Thanks! I wonder if the even EXISTS a custom soft-shell for an O? Makes me nervous anyway....
TAFKAR
Posted 2009-06-19 5:25 PM (#411257 - in reply to #411247)
Last time I flew I watched the baggage handler pick a guitar off the conveyer belt then drop it into the special section for fragile items from a height of 1 metre. Don't take the soft case!
Posted 2009-06-19 8:12 PM (#411258 - in reply to #411247)
Woman down the hall from me went home for Christmas.
She received a Lyon acoustic guitar as a present, she was very happy.
She took a plane home with the guitar in a soft case.
They broke the neck! Then they claim that she had no proof that it wasn't like that when she checked it.
Yes, it was a cheap guitar... But it was Her Guitar.
Do Not Check A Guitar In A Soft Case!
Miguel - BR
Posted 2009-06-19 9:03 PM (#411259 - in reply to #411247)
January 2009
Ok, I am beggining to worry. Would it help to put some kind of padding inside the case? What kind of padding would help? Stirofoam?
AussieJames
Posted 2009-06-19 9:16 PM (#411260 - in reply to #411247)
June 2007
In an original Ovation hardcase no padding necessary.
If it makes you feel better put some bubble wrap around the headstock and make sure you back the strings off a couple of turns.
I have brought three guitars back to Oz and I had to gate check them each time from LA to Bris, domestically in the US carry on.
The staff were courteous and I have had no problems.
Miguel, where are you flying to?
AJ
Posted 2009-06-19 10:24 PM (#411261 - in reply to #411247)
Check the airline's website for their policy on musical instruments. Some airlines specifically permit a musical instrument as long as it fits in the overhead compartment. Some airlines specifically don't allow instruments in the overhead that are bigger than a regular carry on suitcase.
Print out a copy from the website and take it with you to the airport. That way if anybody gives you trouble you can whip out their policy from their website and point out that you are permitted to take it on the airplane.
Many airlines will specifically deny any liability for musical instruments as checked baggage if they are tuned to concert pitch. So if it gets checked be sure it is detuned a bit. None will accept liability if it is in a soft case.
Your best bet is to hand carry it to the gate and get it gate checked if it has to go checked. It will get hand carried rather than tossed around with all the other checked bags. It isn't all that rare to see a bag cart driver making a high speed sudden swerving turn which causes a bag to fly off of the cart onto the ramp. Gate checked bags are hand carried and are usually stowed in a different area. You may get the guitar back planeside at destination.
Check to see if the flight is on a regional jet. Even though the ticket says the name of a major airline, many flights are flown by subcontractors on the RJ. Guitars definitely do not fit in the RJ, but if the flight isn't full you might sweet talk the crew into using a closet or even strapping it into an unused seat. Yes, that is legal as long as it does not block an exit!
The main carrier's website will list the type of aircraft scheduled for that flight.
You have no idea! People are checking so few bags that we regularly have to put on ballast to get the airplane into proper balance! Airliners are designed with a presumption of a certain ratio of checked bags to passengers, and when that doesn't happen in real life we have to move people around or use ballast.
Posted 2009-06-20 2:27 AM (#411262 - in reply to #411247)
Leave the luggage in the overheads and put the passengers who brought more than their share of carry-ons in the luggage hold...
Miguel - BR
Posted 2009-06-20 9:44 AM (#411263 - in reply to #411247)
January 2009
AJ
Miami and then back. I will see around a bit also. I will be flying American Airlines, they say its a 777 on their website. I´ve never had a problem carrying a guitar as hand luggage here in Brazil, but people usually brings lots of things from the US to Brazil, and I´m afraid the crew won´t let me carry the guitar on the flight back.
AussieJames
Posted 2009-06-20 12:22 PM (#411264 - in reply to #411247)
June 2007
Miguel,Miguel, haven't we taught you anything? :rolleyes:
The idea is to go to Miami empty handed an take a new one home :D
Trader Jim is in Florida, he'll hook you up.
AJ
Miguel - BR
Posted 2009-06-20 4:17 PM (#411265 - in reply to #411247)
January 2009
AJ
Quosque tandem, Jimmy, abutere patientia nostra?
Where have you been? You should have checked this thread.
First you take a good look on the map. Then, you draw your own conclusions. After that, we can discuss further who knows what and who should be paying attention to the classes.
Miguel
Miguel - BR
Posted 2009-07-30 4:53 PM (#411266 - in reply to #411247)
January 2009
Well, I´ve flown back with the guitar as carry on all the way.
In Miami I just carried it straight to my seat. It didn´t fit in the overhead bin, so I placed it on the seat and waited. When the crew came check why I wasn´t sitting for the take-off, I said I had nowhere to place the guitar. They offered me a crew closet, after emptying it, so the guitar came to Brazil unharmed.
Then, to fly from São Paulo to Maceió, I just carried it to the plane and placed inside the overhead bin. No problem at all. Obviously, declaring that I had a loaded weapon and was carrying it with me in the plane went a long way to get plentyful smiles all the way around... :D
AussieJames
Posted 2009-07-30 6:21 PM (#411267 - in reply to #411247)
June 2007
Gee Miguel, I've never thought of an Adamas as a "loaded weapon" :D
AJ
Miguel - BR
Posted 2009-07-31 10:41 AM (#411268 - in reply to #411247)
January 2009
It was not the Adamas, but the new-from-Al Al di Meola Custom Legend.
SWMBO asked me to bring a new guitar to Brazil.I had to oblige.
Miguel
