Op-Pro XLR problem...
Posted 2009-08-12 9:49 PM (#403386)
Subject: Op-Pro XLR problem...
i've got a problem i could locate no solution for in my search here and in private messages so i will post it and see what the collective mind comes up with:
as of this morning, the XLR on my 1688 12 string with its Op-Pro preamp will only work if i turn the tuner on. once the tuner times out, the amplified sound goes off. the 1/4" connection works just fine.
i've pulled the can to check and clean all connections and replaced the battery. still no worky.
i've used the XLR many times at gigs and church and it has never offered this trouble before.
y'all got any clues?
PEZ
Posted 2009-08-12 9:51 PM (#403387 - in reply to #403386)
Subject: Re: Op-Pro XLR problem...
July 2003
try a dummy 1/4 and XLR
Posted 2009-08-12 10:00 PM (#403388 - in reply to #403386)
i've not had to use a dummy plug before...
durned xlr thing works when i put a 1/4" dummy plug in though. why now and not before? :confused:
Posted 2009-08-12 10:22 PM (#403389 - in reply to #403386)
i just realized there's a short in the xlr connection. i get a lot of static noise when connecting and if i hold the connector a certain way the xlr works fine without the dummy. putting the 1/4" jack in somehow makes the connection better.
Posted 2009-08-12 10:49 PM (#403390 - in reply to #403386)
Perhaps the 1/4" jack is flakey? Maybe a contact bent in it. I'd look for contacts there, or perhaps a cracked conductor or solder joint in the XLR jack itself.
Posted 2009-08-12 10:51 PM (#403391 - in reply to #403386)
i just took out the assembly and eyeballed it real close. i cannot detect any issues. i've emailed budny to get his take on this.
thanks, pez and flysig.
