Location: Phoenix AZ | Which OP style preamps have a working tuner withOUT having to plug in?
OP-10: ?
OP-20: ?
OP-30: ?
OP-40: ?
OP-50: ?
OP-Pro: ?
OP-ProStudio: ?
OP-VIP: NO
OP-IDEA: NO |
Op-50: Yes |
Location: big island | not to hijack the thread but i'd also like to know which ones have tuners that automatically mute the volume? the OP-PRO doesn't. the OP-50 did. |
Location: Florida Central Gulf Coast | Once the question is fully answered, this would be a great item to add to the FAQ!!!  |
Location: Brighty in Blighty | OP-ProStudio = yes. A good excuse to play my 07C ;) |
Location: Keepin' It Weird in Portland, OR | OP-20, yes!
I don't think that there is an OP-10...
But an OP-11 has No Tuna.
Optima, yes! |
Op-50: mutes |
Location: Florida Central Gulf Coast | Keep 'em coming... I'm building an Xcel sheet that I'll gladly share once complete. |
Location: Yalova/Turkey | OP 30 works without being plugged in and mutes when plugged in. |
Location: Florida Central Gulf Coast | Just a bump for more info...
Preamp........ Tuner.. Mute
OP-11.......... no
OP-20.......... yes
OP-30.......... yes.... yes
OP-40.......... yes.... yes
OP-50.......... yes.... yes
Optima......... yes
OP-Pro......... yes
OP-ProStudio. yes
OP-VIP......... no
OP-IDEA....... no |
(OP PRO does not mute) |
Location: Nashville TN. | which will tun off phantom power?? |
Location: South of most, North of few | The older op24 +C has a tuner too. |
Location: On the Coast - Halfway between SF & OR | Iffy -
I'm getting a bit confused.
Do all the OP preamps have tuners? And your "yes" list is only those that work unplugged?
Sorry for not being able to keep up.
And thanks for tracking everything. |
Location: Florida Central Gulf Coast | Originally posted by fletcher:
Do all the OP preamps have tuners? No. The 'Tuner' column indicates whether the preamp has a built-in tuner. The 'Mute' column indicates if the output is muted while in tuner mode.
I've added another tuner, but I'll wait until we have more info prior to reposting the table.
Keep 'em coming... |
Location: On the Coast - Halfway between SF & OR | Originally posted by 2ifbyC:
No. The 'Tuner' column indicates whether the preamp has a built-in tuner. The 'Mute' column indicates if the output is muted while in tuner mode. OK,
Can you add a column that states whether you need to plug in a jack to get the tuner working? |
Location: Florida Central Gulf Coast | I know the OP-VIP needs to be plugged in. I thought there was one more, but I can't remember which one. I'll asterisk those that do, once I find definitive answers.
As a result of your questions, I started to poke around and noticed an error in the table. I'll correct it when I get more info and repost. |
Location: On the Coast - Halfway between SF & OR | Thanks for taking the time to compile this info! |
