Pick Scratches
Norseman1
Posted 2009-11-30 1:18 PM (#388774)
Subject: Pick Scratches
Hey guys...quick question.
I regularly let students, and recently an aquantaince play my O's. It seems some people are pretty heavy handed with a pick. Anyways, I now have some pretty heavy pick scratching into the rosette and faceboard of my Legend and my Anniversary Model. The Legend I expected as kids pound on it pretty good, but I am a little bummed about the Anniversary Model that I pretty much baby.
Anyways, are these scars absolutely for life, or is there something that can be done...I've heard of guys wet sanding faceboards? I tried rubbing in a little Formby's Lemmon Oil, and polish, but to little effect. The finish has been hit pretty hard.
Appreciate any ideas!
Norse(only stop by when I need something)man1
Posted 2009-11-30 1:31 PM (#388775 - in reply to #388774)
Subject: Re: Pick Scratches
Arm&Hammer toothpaste (though I suspect most brands will do... paste! not gel!) and a soft wet cloth. Be patient. Move in circles.
Norseman1
Posted 2009-11-30 1:48 PM (#388776 - in reply to #388774)
Really?! Wow, and that's even something I..the Norseman...can actually handle doing!
Norse(as long as I spit my gum out before I start)man1
Norseman1
Posted 2009-11-30 1:51 PM (#388777 - in reply to #388774)
Now I am confused...I just don't understand why I need to move in a circle while doing this...do I take the guitar with me? Or, do I complete each circle before rubbing the scratches again?
Norse(confused easily)man1
seriously though...thanks for the tip!
Posted 2009-11-30 2:56 PM (#388778 - in reply to #388774)
Use a swivel chair or stool, but I recommend a low one, so it doesn't hurt as badly when you get dizzy and fall off.
I suspect Jeff's Arm & Hammer recommendation may be a cheap substitute for guitar or car scratch remover. A&H may have some baking soda, which acts as a finishing compound.
Posted 2009-11-30 3:08 PM (#388779 - in reply to #388774)
I'm just thinking of how I spent good money on a jar of stuff that Looks like Crest outta the tube.
And now you are telling me that I coulda went to the Dollar Store and got a tube of toothpaste! :confused:
Gallerinski
Posted 2009-11-30 3:47 PM (#388780 - in reply to #388774)
Toothpaste also makes for a good nail hole filler in the walls
Posted 2009-11-30 4:40 PM (#388781 - in reply to #388774)
Say OMA, look at the bright side. You now have an emergency supply of toothpaste.
Norseman1
Posted 2009-11-30 4:49 PM (#388782 - in reply to #388774)
...that reminds me...did you know that a guy from Arkansas invented the "toothbrush"....yea, if it would've been someone from any other state, it would've been called a "teethbrush"!
Norse(sorry about that razorbacks)man1
Jonmark Stone
Posted 2009-11-30 5:20 PM (#388783 - in reply to #388774)
I use Crest paste on tuners as well. Just like a car wax, apply with a slightly damp cloth and let haze over. Then polish with clean dry cloth.
I don't do it often... I guess every few years. And I usually completely remove the tuners, nuts and washers. But it'll really make an older set of gold Schaller's look nice.
Posted 2009-11-30 5:48 PM (#388784 - in reply to #388774)
Toothpaste also makes for a good ...
... scratch remover for wrist watch dial faces.
Posted 2009-11-30 5:52 PM (#388785 - in reply to #388774)
Here ... lemme take the scratches outta your guitar and wristwatch.
Be patient. Move in circles. After a couple of minutes, you'll never even know that they were there! :D
Posted 2009-11-30 6:52 PM (#388786 - in reply to #388774)
We used to do that when moving from an apartment when I was in college. I told a friend about the idea, and he tried it. Got back to me a week later and said it didn't work. I found out later he was using Closeup, which is red.... :rolleyes:
standing
Posted 2009-11-30 11:05 PM (#388787 - in reply to #388774)
December 2008
+1 on that - Someone here (probably Jonmark) once recommended Crest toothpaste for tuners when I was trying to clean up a disgustingly filthy MEII I bought. At first, I thought it was a joke, but I tried it, and it worked amazingly well, they looked practically brand-new afterwards, and smelled great too! (Plus… it's cheap and readily available.)
FlicKreno aka Solid Top
Posted 2009-11-30 11:41 PM (#388788 - in reply to #388774)
So , NORSEMAN is Not Scandinavian then .. ??! ..
AussieJames
Posted 2009-12-01 5:23 AM (#388789 - in reply to #388774)
June 2007
Any ideas?
Grab a coupla beaters!!
AJ :D
Norseman1
Posted 2009-12-01 9:35 AM (#388790 - in reply to #388774)
yea, you betcha I am. I moved down der to da soudwest to gedaway from dat dere cold in Minneota.
Norse(UUUFDA Da weader soo much nicer down here don'tcha know)man1
Auriemma
Posted 2009-12-02 9:23 AM (#388791 - in reply to #388774)
October 2008
Norse,
If they a grooves in the wood (not scratches), smile and move on. Nothing can be done. If they are truly just scratches, Maquires X polish will take them out and make the top like a mirror.
nervous
Posted 2009-12-02 4:16 PM (#388792 - in reply to #388774)
May 2009
What is the worry (if any) about using auto type cleaners and polishes that contain silicone vs. instrument (and some Maguires pro products) that do not? I use a mirror glaze (#4 I believe) for stratch removal and I believe that I does not contain silicone. Finish with Stelling Glyde Cote (the best guitar polish I have ever used).
