a question for all the resonator owners out there
Designzilla
Posted 2010-01-01 9:06 PM (#384409)
Subject: a question for all the resonator owners out there
What strings do you use on your resonator? It's WAY past time to change the strings on my National and I'm not sure what to use.
What do you like?
Posted 2010-01-01 9:14 PM (#384410 - in reply to #384409)
Subject: Re: a question for all the resonator owners out there
I just went to the store to buy strings for the first time for mine and they recommended Phosphor Bronze 13 or 15s. The one's that came on mine were too light. I haven't changed them yet... I'll let you know how they are when I do.
fletcher
Posted 2010-01-01 9:53 PM (#384411 - in reply to #384409)
March 2009
I usually use Jagwire nickel wound Gary Morse - Artist Series or D'Addario EFT13 flat tops.
I find the phosphor bronze a bit too bright.
Posted 2010-01-01 10:40 PM (#384412 - in reply to #384409)
medium ph/bz
Posted 2010-01-02 11:50 AM (#384413 - in reply to #384409)
I either missed it or forgot it... when did you get a National, Zilla?
I've just got EJ42's on mine. I figure they say resophonic, so I use 'em.
Posted 2010-01-02 3:44 PM (#384414 - in reply to #384409)
EJ42's are intended primarily for squareneck, wooden-bodied spider-cone guitars (i.e. Dobros) They'll work for regular upright slide on a bunch of other resonator guitars but at .016 to .056 they're pretty brutal if you need to fret past position 3. As Beal said, a medium gauge set will do the job, though for slide I always increase the first string to at least a 0.015.
The EJ42 pack says "Resophonic" but really they mean "Dobro" However, now that our litigious pal Hank owns the brandname he's made it known to the industry that anyone using the word "Dobro" except Gibson will get sued.
Posted 2010-01-02 11:22 PM (#384415 - in reply to #384409)
Thanks. That's good info.
Designzilla
Posted 2010-01-03 1:13 PM (#384416 - in reply to #384409)
Thanks Paul, I was wondering about the resophonic strings, cause a lot of them seem to be for square necks.
Another question...
The action is just a bit low for slide playing, especially on the bass strings. How can I raise the action. Do I need to raise or replace the nut?
Hey Jas, I've had this for about a year I think. Its a custom M2 I bought on ebay. Here's a picture of one exactly like mine, or it could be mine depending on when the previous owner bought it.
I definitely has a different sound than the metal ones.
Posted 2010-01-03 1:20 PM (#384417 - in reply to #384409)
Another question...
The best way is to make a new nut, but for a quick fix you can just shim it up. Doesn't need to be much, about 1mm should give you enough extra clearance. You might also consider backing off the neck-rod a tad to get a little more clearance around the middle of the fingerboard. Don't overdo it though.
The M2 is probably the best wood-bodied biscuit-cone reso available.
Designzilla
Posted 2010-01-03 1:37 PM (#384418 - in reply to #384409)
Thanks Paul. Just what I needed to know!
Posted 2010-01-03 9:17 PM (#384419 - in reply to #384409)
Actually you want to raise the bridge, not the nut for a little higher action. Bring it to G8R bowl.
Also elixers work well with a slide, cuts down the extra slide noise and go up on the high E like Paul said.
Posted 2010-01-04 7:13 AM (#384420 - in reply to #384409)
I guess it depends on the player. I've noticed that most of your Resos are low at the nut. I'm not comfortable playing slide with a standard nut action, I like it just a little higher. Not so high that fretting becomes difficult, but just enough to keep it clean, especially with a heavy slide.
Posted 2010-01-04 9:11 AM (#384421 - in reply to #384409)
true
