Adamas bracing.
maliberd
Posted 2008-04-29 9:53 AM (#42268)
Subject: Adamas bracing.
A friend from OT told me that the bracing on the 2 RI adamas 1687 and 1187 don't have the same bracing. Same pattern but different sizes of each strip of wood. Anyone know the reason why ?
Charlie Ramon
Posted 2008-04-29 10:22 AM (#42269 - in reply to #42268)
Subject: Re: Adamas bracing.
August 2004
The 1187 bracing is lighter. Lighter bracing - better sound. It's that easy. The #47 reissue is the best sounding Adamas I know. I assume that only the originals sound better (whatever "better" means).
Karl
maliberd
Posted 2008-04-29 11:27 AM (#42270 - in reply to #42268)
Karl,
I would not exactly say that but rather, lighter bracing, different sound : higher fundamental soundboard frequency, more overtones, but I never play both just one after the other to compare. I will probably do it this week, I'll give you my filling after that...
Bernard.
Posted 2008-04-29 1:40 PM (#42271 - in reply to #42268)
If you line up an OFC Guitar, a 47RI and an Original Slothead you will conclude that they are A+, A++, and A+++ guitars. Just my opinion.
Posted 2008-04-29 2:35 PM (#42272 - in reply to #42268)
Dave, is that perspective from when you play them or somebody sitting across from you playing them at you? Same strings on all?
Tim in Tidewater
Posted 2008-04-29 2:58 PM (#42273 - in reply to #42268)
December 2005
Well SWMBO can tell the difference between the two from the next room.
Same strings & unplugged, she says the 47RI has more higher chimey tone whereas the OFC has more of a deep Bass resonance.
Posted 2008-04-29 3:02 PM (#42274 - in reply to #42268)
Both. Same as Tim said. OFC has a bigger bottom end. But they are all pretty close.
Posted 2008-04-29 3:05 PM (#42275 - in reply to #42268)
I should have got one of those 47RIs just to see if SWMBO could tell the difference, I guess. Other than one is red and one is blue. I don't know if I could tell the difference among my guitars if I was blindfolded, and I think I have quite a variety.
Posted 2008-04-29 6:00 PM (#42276 - in reply to #42268)
from the other room, in the closet, blindfolded, or hanging from the ceiling...you can tell the difference between the 47RI and the OFC...just as you can tell them from a 1687.
Posted 2008-04-29 6:52 PM (#42277 - in reply to #42268)
I really couldn't tell the difference between my OFC, your's or your 47RI when I was at your place last summer, Tony. I must admit, however, that I was a bit overwhelmed by so many guitars that I couldn't move without tripping over another one.
Beggin
Posted 2008-04-29 7:35 PM (#42278 - in reply to #42268)
Mark,
are you referring to Tony's place or your's? :rolleyes:
