Pick guard advice needed
AlanM
Posted 2010-02-20 1:22 PM (#378948)
Subject: Pick guard advice needed
I have an absolutely glorious FD-14 wide-neck that doesn't have a pick guard... I'm figuring that since this is primarily a finger-pick-type guitar, it typically doesn't really need one. However, I'm a flat-picker, and it's just wonderful for me. I have mondo hands, so the wide-neck's very comfortable for me.
However, here's the problem. I do fast runs up and down the neck, and when I do, I rest my picking hand pinky on the soundboard. Well, I can see that after some time, the finish seems to be starting to wear away a bit. It's showing kind of a "friction shine," for lack of a better term.
I'm wondering if there is something like a temporary pick guard that I can adhere to the top to protect the finish without (1) damaging the surface when I take it off, or (2) overly dampening the beautiful sound this sweet guitar produces.
Thanks, all!
Alan
Posted 2010-02-20 1:33 PM (#378949 - in reply to #378948)
Subject: Re: Pick guard advice needed
Pic guard on an Ovation???
Sacrilege!
And they look just gawd awful.
I'd say change your technique (unlikely)
Or, let the wear come where it may let it show like a badge of honor. Unless it's a kept in a glass case collectors model, play it. Play it hard and play it proud.
It's a tool.
Isn't that true of each and every Ovation model ever made?
Darkbar
Posted 2010-02-20 1:45 PM (#378950 - in reply to #378948)
January 2009
Wear a pinky glove on that finger. Check Musician's Friend
AlanM
Posted 2010-02-20 2:13 PM (#378951 - in reply to #378948)
Sacrilege!
It's a tool.
Thanks, SlipKid! Lots of good points. It IS a conundrum...I DO appreciate the idea that a lovingly played guitar is REALLY more beautiful (sound- AND looks-wise) than a pristine, unplayed museum piece.
About changing techniques, you truly DO have a great point...However, I've received recent feedback that I should explore greater variety of expression in my current technique. I think I want to be a master of that genre, rather than a jack-of-several genres. The additional problem is that -- to my ear at least -- the FD-14 just
sounds spectacular when flat-picked. I DO want to continue to explore that.
Bottom-line: I'm lookng for a temporary adhesion type of thing that would protect the finish of the beautiful FD-14, while not harming its equally beautiful sound. The FD-14 is TRULY a gorgeous instrument.
AlanM
Posted 2010-02-20 2:15 PM (#378952 - in reply to #378948)
Hmmm...great idea! Didn't think of it from THAT perspective!
Thanks, DB!
swabianrock
Posted 2010-02-20 3:59 PM (#378953 - in reply to #378948)
August 2009
I just ordered clear removable pickguards for my KOA collector 2009 an 2078 LX Elite (see http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290403160894). It seems that the new thin polyurethan finishes are more sensitive than the older ones.
Jim E
Posted 2010-02-20 4:00 PM (#378954 - in reply to #378948)
December 2009
They make a "static cling" protective plastic for just this purpose. Clear with no adhesive, it stays put until you just peel it off. It is usually refered to as finish guard. Automotive supply houses will probably have some.
bvince
Posted 2010-02-20 4:12 PM (#378955 - in reply to #378948)
September 2005
It's really ironic that you asked this question. I was just checking out some chord variations on my Guitar Power software, and saw a link to that invisible removable pick guard. The one advertised there was about $10, but I'm sure the product JimE mentioned above is the same material at a substantially lower cost, and will give you a lot more. There's a guy in our group that strums very hard on his taylor guitar, and it has now worn away a large portion of the edge of his sound hole. I'd bet he would have liked to know about that stuff a while ago.
Posted 2010-02-20 4:22 PM (#378956 - in reply to #378948)
For all you thrasher, beater, power-stroke guys out there, they got this new thing out called an amplifier.
Check into it.
A clear pic guard sounds like a good enough idea. Just don't leave one on long enough to make the top age differently.
Posted 2010-02-20 4:48 PM (#378957 - in reply to #378948)
I have gotten them before from These Folks!
If you have a multi-hole Ovation or an electric I recommend GB#9, which is a big sheet of material that you cut yourself. It is 9x12" so you can make two-or-three.
For center-hole guitars they have pre-cut ones that come two-to-a-sheet.
Posted 2010-02-20 5:59 PM (#378958 - in reply to #378948)
leave it alone and don't worry about it.
that was not a wiseass answer.
Posted 2010-02-20 6:29 PM (#378959 - in reply to #378948)
Are you sure?
Gallerinski
Posted 2010-02-21 9:11 AM (#378960 - in reply to #378948)
Buff the top of the guitar so the whole thing shines. Then you won't see difference to the area where you rest your finger.
Posted 2010-02-21 9:58 AM (#378961 - in reply to #378948)
Friction shine is good. It gives the guitar character without doing damage.
AlanM
Posted 2010-02-21 10:05 AM (#378962 - in reply to #378948)
IMPORTANT detail there. SK! Thanks!
Jonmark Stone
Posted 2010-02-21 12:54 PM (#378963 - in reply to #378948)
I agree with Bill. Just play it...
Posted 2010-02-21 2:05 PM (#378964 - in reply to #378948)
ditto.
dobro
Posted 2010-02-21 6:57 PM (#378965 - in reply to #378948)
Don't be intimidated by purists, Alan. I have a clear adhesive cut from something like this on two of my O's and love it.
