Questions about refinishing/repairing an O top
Norseman1
Posted 2010-03-09 11:08 AM (#377486)
Subject: Questions about refinishing/repairing an O top
OK, I have a beat up Ovation that I want to try to somewhat resurrect. Is it possible to strip the top on an epaulet faced guitar? Also, for gluing down a pulled up bridge (wood came up with it)...would carpenter's glue work OK?
I know I should refer these repairs to the professionals, but my budget says that won't be happening....I will be OK with less than professional results, I just want to try and clean her up and make her functional.
Any ideas would be helpful....thanks.
Norse(I can cut and split wood, but that's about it)man1
Mitzdawg
Posted 2010-03-09 11:54 AM (#377487 - in reply to #377486)
Subject: Re: Questions about refinishing/repairing an O top
July 2004
Norse,
I have stripped the top on an 1868; it can be done, just a lot of fussy sanding around the Epis. It now resides in the Great White North.
You can use Titebond to reglue the bridge (use clamps!).
I have also drilled a countersunk hole in a lifted bridge, installed two button head screws and covered the heads with fake abalone dots. Put in a bridge plate or washers on the back to prevent pull-through. Do it right and it looks great and nobody will know the difference.
'Dawg
Posted 2010-03-09 12:32 PM (#377488 - in reply to #377486)
At the factory (at least this is what I was told by somebody there) they literally sand down the whole top, saddle, epaulets, and all. Then they refinish the top adding new epaulets and a new bridge.
Norseman1
Posted 2010-03-09 1:42 PM (#377489 - in reply to #377486)
...so it can be done...I am going to make this a summer project once I get back to the Great White North.
Thanks for the advice...
Norse(Hey Paul!)man1
Posted 2010-03-09 1:47 PM (#377490 - in reply to #377486)
Get one of those fancy detail sanders, with the pointy nose on it. Probably make the sanding around the leaves a tad easier.
Norseman1
Posted 2010-03-09 4:17 PM (#377491 - in reply to #377486)
...is there a particular stripper that is better than others?
Norse(just set up every pervert on the board!)man1
Posted 2010-03-09 5:15 PM (#377492 - in reply to #377486)
Hold on... be right back...
bvince
Posted 2010-03-10 8:39 AM (#377493 - in reply to #377486)
September 2005
When I discussed removal of the epaulets on mine with Kim, he said they will first try using heat to remove them. So I would guess a heat gun or blow dryer to start with and something like a wood chisel to pry with. As far as a proper stripper to use, just remember it is Laquer you are removing. That makes a big difference on what to use. What ever you do, stay away from the binding and joints as much as possible. If something comes loose THERE you may have a difficult time making it right. Sounds like a fun project if I had a beater to experiment on.
Jonmark Stone
Posted 2010-03-10 12:48 PM (#377494 - in reply to #377486)
Actually it's catalyzed polyester, not lacquer. Strippers barely dent that stuff in my experience. Refinishing anything on an O requires a lot of sanding and elbow grease.
cholloway
Posted 2010-03-10 1:05 PM (#377495 - in reply to #377486)
We must be getting old!
