What I did today: I found a date under the bridge, then lubed my nuts...
Posted 2008-05-05 1:28 AM (#41260)
Subject: What I did today: I found a date under the bridge, then lubed my nuts...
The production date on the PF-22 wasn't on the side of the headstock, but it WAS under the bridge/tailpiece...
March 20, 1980.
After, I went to the guitar store and picked up this stuff to lube the nuts on the guitars that were having the tuning "pings".
All gone now. This stuff works great!
maxdaddy7271
Posted 2008-05-05 3:24 AM (#41261 - in reply to #41260)
Subject: Re: What I did today: I found a date under the bridge, then lubed my nuts...
March 2006
A #2 pencil has never failed me. I put a graphite nut on my Breadwinner/Deacon LTD, and it's never failed me, either. If it works, don't fix it, but remember that the bridge is also a contact point, and a touch of graphite on it probably won't hurt.
numbfingers
Posted 2008-05-05 10:22 AM (#41262 - in reply to #41260)
Maxdaddy, were you able to use an off-the-shelf graphite nut?
Erniewan
Posted 2008-05-05 10:50 AM (#41263 - in reply to #41260)
June 2004
I've used the GHS graphite with great results, and it won't discolor the nut.
Posted 2008-05-05 11:59 AM (#41264 - in reply to #41260)
I even used it on the UKII's brass nut. I wish I would have looked for this stuff sooner. That one's been pinging for a year now.
Simple to do too. I used a high E string as my "brush". Dipped it in the stuff then slid it all around the slot.
Posted 2008-05-05 12:03 PM (#41265 - in reply to #41260)
The best title for a thread and you get four serious responses. If you have a serious title all you ever get is a bunch of smartass responses. This board is nuts.
Posted 2008-05-05 12:20 PM (#41266 - in reply to #41260)
lubed nuts.
Phil Wong
Posted 2008-05-05 12:52 PM (#41267 - in reply to #41260)
Cashew Nuts.
Posted 2008-05-05 12:59 PM (#41268 - in reply to #41260)
Gesundheit
Posted 2008-05-05 1:19 PM (#41269 - in reply to #41260)
Ask and ye shall receive Mark
Posted 2008-05-05 1:48 PM (#41270 - in reply to #41260)
It never takes long.
Posted 2008-05-05 2:54 PM (#41271 - in reply to #41260)
Just needs a kick in the right direction sometimes. Glad you were there to help out Mark.
Posted 2008-05-05 4:18 PM (#41272 - in reply to #41260)
Is 32080 or 52080. ALl of the PF Basses I have are 5xx080 indicating May of 1980.
Posted 2008-05-05 6:01 PM (#41273 - in reply to #41260)
Pretty sure it was March. I'll look again though. I noted it cuz it was 5 days after I turned a teenager
