Location: europe | does anyone have a photo of an original slothead case with the sparkle finish ?
thks gerry |
Location: europe | or let s say, how did those look, i never saw a sparkle case with the sparkle case cover. |
Location: 6 String Ranch | They were the regular brown cases with the color sparkles of that guitar, each -number had a different combination of color sparkles, mixed with clear and sprayed over the case. It was fairly subtle but that's why they came with a case cover, which was plain. |
Location: europe | beal thanks for the fast and detailed reply.
did the case cover also have sparkles? |
Location: europe | beal, after reading your post again, i saw the last comment which say that the cover was plain. so no need to reply to my last question. thks |
Location: europe | just one more question, were the color sparkles those of the bowl or of the top ? |
Location: europe | and the last - were the sparkles sprayed over the case like on the gutiar - more outside less in the middle or all over the case in the same amount. |
Location: 6 String Ranch | They were just sprayed evenly with top sparkles except for the left handed cases which had a heavier bursting of spray around the handle area to hide the patch holes from where the handle was moved to the other side. |
Location: Latitude 39.56819, Longitude -105.080066 | gerald...time to be more specific.
Where in Europe? |
Location: Atlanta, GA. | I think Beal is hallucinating again...
He's the only one to ever see a sparkle case! :D |
Location: europe | you think just remembering the spray of the clearcoat with sparkles causes hallucination ;-))) |
Location: europe | stephent - ;-) i only want to know how it looked, i did not find one, unfortunately. |
Location: 6 String Ranch | must have been the fumes.......... |
Location: Latitude 39.56819, Longitude -105.080066 | translation issues. |
Location: europe | al - i found a thread from you when you found that red slothead, in think #28. you mentioned that the case was brown with sparkle.
do you have a photo of that case? |
They were just sprayed evenly with top sparkles except for the left handed cases Why would there be right & left handed cases?
And did someone ask for them?
Just curious...
I always carry my guitars so that if the case were to open the lid of the case would hit my leg preventing the guitar from falling out. |
Location: Tennessee | :D Must have been the fumes ... |
Location: europe | colin, i put always a belt around the case. i am always afraid that the handle break and the case fall down. |
Location: Utah | These days I don't worry about a case opening up, but I am a bit OCD about making sure all the latches are done up. Back in the pre-car days, I used to ride my bicycle carrying a guitar virtually every day. To/from school, to/from friends' houses, etc. I never had a case open unexpectedly. One case, for the long-gone early 70's Strat, had less than secure latches, so I always used the key to lock the center latch. |
do you have a photo of that case? nope no photo |
Location: Colorado Rocky Mountains | Another reason for my preference for soft sided cases. . . there is much less likelihood of the zipper inadvertently coming undone and the contents falling out at a most inopportune time. You younger guys wouldn't understand, but live long enough and you will. |
Location: Boise, Idaho | "You're not really old when you forget to zip it up. You're really old when you forget to zip it down." A really old guy told me that 25 years ago, when he was my age. |
Location: Atlanta, GA. | there is much less likelihood of the zipper inadvertently coming undone and the contents falling out at a most inopportune time. This used to happen to Pinky Como all the time. :eek:
I think they make him wear diapers now! |
