whats the best way to clean dust out of the pick up
slothead
Posted 2010-10-25 6:09 AM (#362405)
Subject: whats the best way to clean dust out of the pick up
July 2004
ive got a 1614 folklore and it crackles a bit when plugged in i asked about this in a local guitar shop and they told me to use servosil elctrical contact cleaner in an aerosol can just wanted to ask on here before i use it
G8r
Posted 2010-10-25 10:49 AM (#362406 - in reply to #362405)
Subject: Re: whats the best way to clean dust out of the pick up
Assuming the crackling only happens when you turn the volume or tone knobs, any electrical contact (pot) cleaner will work. You wouldn't spray it on the pickup as there are no moving contacts there, just piezo crystals. You have the stacked knob pre-amp, right? Just spray some pot cleaner onto the shaft and let it work its way down. If the crackling only occurs when you jiggle a plugged-in instrument cable, then the jack contacts may be loose, in which case you unscrew the jack and bend the contact pins inward a bit (assuming the wires are well soldered on the jack pins).
Posted 2010-10-25 11:22 AM (#362407 - in reply to #362405)
After blowing out some of the dust twist the knob around, about 25 times.
Styll
Posted 2010-10-25 11:38 AM (#362408 - in reply to #362405)
any other guitar i would say dunk it in your neighbors pool... ;)
slothead
Posted 2010-10-25 12:25 PM (#362409 - in reply to #362405)
July 2004
good stuff cheers!
