CC059 Nylon and iDea .. do I dare??
kentrookie
Posted 2010-11-16 11:27 PM (#361250)
Subject: CC059 Nylon and iDea .. do I dare??
December 2008
I received a "extra" iDea preamp as a gift.
Any thoughts on if the iDea would work well with a nylon ovation (Celebrity). Is the pickup for a nylon Ovation fundamentally different that a steel string?
kitmann
Posted 2010-11-17 2:38 AM (#361251 - in reply to #361250)
Subject: Re: CC059 Nylon and iDea .. do I dare??
April 2010
I have a nylon Celebrity also, I like to know if it sounds good.
Posted 2010-11-17 3:08 AM (#361252 - in reply to #361250)
If your CC059 has an OP20 preamp in it, I don't see why it wouldn't work.
That is the same undersaddle pick-up.
And if an OP20 will work with nylon, I don't see why the iDea wouldn't.
Go for it, and let us know how it turns out.
If you don't drill the hole for the 'aux' jack, you can just switch it back if it don't work.
Posted 2010-11-17 8:40 AM (#361253 - in reply to #361250)
Yeah, but will the "can" accept the iDea? I thought there was some difference in the receptacles between the two generations of preamps.
Posted 2010-11-17 11:35 AM (#361254 - in reply to #361250)
To check for compatibility just look at the connector on the bottom of the modules. New ones have 8 copper tabs in a symmetrical layout, 2 rows of 4. Older modules such as OP30 have 7 tabs, 3 on one side and 4 on the other.
Posted 2010-11-17 1:45 PM (#361255 - in reply to #361250)
seesquare asks:
Of course not. (That would be much too easy)
I am running with the assumption that he got the iDea can with the iDea preamp.
BTW-- The iDea Module will run in an OP-Pro can...
BUT an OP-Pro module will NOT run in an iDea can.
