Ovation cases, 8158 and 9158 difference
WaltCL
Posted 2010-11-26 4:45 PM (#360733)
Subject: Ovation cases, 8158 and 9158 difference
November 2010
What is the difference between the 8158 molded case and the 9158 deluxe molded case. I see the logo on the front is different and the 9158 has the Ovation name printed on the inside plush, but their must be some other differences.
Posted 2010-11-26 4:52 PM (#360734 - in reply to #360733)
Subject: Re: Ovation cases, 8158 and 9158 difference
A more heavy duty handle on the 9158...and about $50 retail depending on where you buy it.
Posted 2010-11-26 4:52 PM (#360735 - in reply to #360733)
Some 9158's have a softer handle. But not all of them.
And some have a place to put the truss-rod wrench.
But mostly, it is the "Ovation" in the fur...
WaltCL
Posted 2010-11-26 5:16 PM (#360736 - in reply to #360733)
November 2010
Wow! I'm surprized. No difference in the fur, the padding, locks, etc.. Just the handle and name logo. For the extra money I thought the deluxe might be stronger or have better features then the standard case.
Posted 2010-11-29 8:33 AM (#360737 - in reply to #360733)
Maybe if you're 6'5" and weigh 250 pounds you won't feel the difference in the two cases, but, at 5'5' and less than 140 pounds, the differences are pronounced. There's a very big difference in how balanced they feel when they're being toted--when you're petite like me, the 8158s don't snug up next to you, and are much more cumbersome.
The deluxes are much trimmer, inch-wise. The first cases I measured contain super-shallow bowls. The deluxe bowl-end has a footprint that is 5 1/2 inches; the other is 7 inches. The thickest point on the deluxe is about 7 3/4 inches; the other is 8 1/4. The "feet" used to rest the cases on are very different--I've never seen them missing or pushed in on the better cases, but have noticed that on the cheaper ones.
I just measured Gertrude's case (she's original deep bowl), and that deluxe is still much slimmer than the 8158, even though she's so much bigger.
There's a lot more to the differences than just the writing in the cases--the measuring tape proves it.
--Karen
Posted 2010-11-29 9:43 AM (#360738 - in reply to #360733)
The harder the material and stronger the case, the bigger the dent, rip or scratch in or on whatever they bang into, which is why I prefer the vinyl-covered hard-foam cases. For everyday use to and from gigs, they hold up well, save upholstery and door jams, and can be carried on a shoulder, leaving your hands for the other gear and doors.
