Ovation Battery Pack Clip
daguitaristz
Posted 2010-12-26 4:34 PM (#358773)
Subject: Ovation Battery Pack Clip
May 2007
Hey guys! I just picked up a blue sumburst 83 Ultra. It's fun and sounds great!
Unfortunately, the battery pack inside has been modified. The battery pack clip (held in by a screw on the side) is bent out of place and can no longer be held in place by the screw. I would like to reform the clip into place, but I don't know what shape it should take. Can anyone take a photo of the clip on the battery pack? Thanks!
Also, in case it won't work, any recommendations on where to get a replacement pack/clip?
Happy pickin! Ultra Battery Replacement - Type of Battery I Have
Posted 2010-12-26 5:40 PM (#358774 - in reply to #358773)
Subject: Re: Ovation Battery Pack Clip
Haven't got an instrument with the battery pack like yours, but have, in the past. The slot in the battery case is a female version of the holding screw, which is essentially "T"-shaped on the end, and pressed through the slot in the metal plate case, then turned 90-degrees, to lock the assembly. -I --> II --> I=
cholloway
Posted 2010-12-26 8:33 PM (#358775 - in reply to #358773)
Otherwise, should work just like you say.
Gallerinski
Posted 2010-12-27 12:41 PM (#358776 - in reply to #358773)
VELCRO
