buzz
slothead
Posted 2011-01-13 12:14 PM (#357602)
Subject: buzz
July 2004
just put new strings on my guitar and noticed the D STRINGS buzzing it wasnt like that before and i checked the bridge pin and it seems fine does anyone know what it could be ?
Posted 2011-01-13 12:21 PM (#357603 - in reply to #357602)
Subject: Re: buzz
"Checked the bridge pin"? Obviously, the problem is that it's not an Ovation....
slothead
Posted 2011-01-13 1:36 PM (#357604 - in reply to #357602)
Subject: Re: buzz
July 2004
no its a martin om42
Posted 2011-01-13 2:32 PM (#357605 - in reply to #357602)
Subject: Re: buzz
Is the string gauge the same as before?
Nice guitar, btw.
slothead
Posted 2011-01-13 2:46 PM (#357606 - in reply to #357602)
Subject: Re: buzz
July 2004
yes elixrs nanowebs 12's googled it and theres loads of questions on it, mine just seems strange as it wasnt like that before probably going to take it to a guitar workshop if it continues as i dont want to start messing with the truss rod
Posted 2011-01-13 3:34 PM (#357607 - in reply to #357602)
Subject: Re: buzz
Just thinkin'..... is there any "play" in the angle of the saddle? If it tilted forward a bit, it might cause some buzzing?
Could be the neck straighend a bit during the restringing, and will return to its "usual" curvature?
BTW, where is the buzzing occuring? Maybe your nut slots are getting deeper?
Remember, "someone's opinion, & a dollar, will get you a dollar"
Darkbar
Posted 2011-01-13 3:35 PM (#357608 - in reply to #357602)
Subject: Re: buzz
January 2009
Truss rod? I think you should always start with the saddle. Or do you think the trust rod is vibrating?
slothead
Posted 2011-01-14 6:41 PM (#357609 - in reply to #357602)
Subject: Re: buzz
July 2004
if i play the string open it dosnt buzz when i fret it at the 2nd fret it buzz's when the strings hit , iam hitting it harder to try locate were its coming from it sounds from the bridge pin area but cant be 100% certain i did take all the strings off at once when changing them i've since been told to do them one at a time, now am thinking i've took all the tension out of the neck and this is causing the problem, i am torn as to whatit could be, thanks for the replys btw!
Posted 2011-01-14 10:52 PM (#357610 - in reply to #357602)
Subject: Re: buzz
Does it buzz with the same note on a different string? If it buzzes on that same note it would be something like a brace, truss rod, wire touching the back of the top, etc. If it only buzzes on that string on that fret it could be a fret problem. A good straight edge that spans 3 frets will help identify if there is a high or low fret. Look carefully at the 3rd and 4th frets to see if one of those looks like it is coming up.
Posted 2011-01-17 7:17 PM (#357611 - in reply to #357602)
Subject: Re: buzz
Taking all your strings off at once shouldn't be a problem. I do it at least once a year on all of my guitars while I am doing my annual fretboard cleaning.
