Wanted: Bone/Tusq Saddle for S771 Balladeer
Tim in Yucaipa
Posted 2011-03-08 7:05 AM (#355026)
Subject: Wanted: Bone/Tusq Saddle for S771 Balladeer
....my S771 has the Delrin Compensated saddle that is deforming under the strings. I have it strung with the Nashville High strings and the octave G string is burying itself in the saddle!
I want to replace the Delrin saddle with a bone or Tusq saddle.
The Mothership does not have any...only Delrin (rather odd methinks). So, before I stop at the local Music Store or GC, I thought I'd check the Hive Mind.
Anyone here have an extra blank that's not needed? I'm most happy to pay! If not, I'll stop and buy a blank (two actually because I'll probably ruin the first one)....I have a Dremel Tool somewhere that I can use....
Many Thanks!
scott lamperd
Posted 2011-03-08 2:59 PM (#355027 - in reply to #355026)
Subject: Re: Wanted: Bone/Tusq Saddle for S771 Balladeer
If you can't find one, Steward Mcdonald carries about everything you'll need. They are on line.
scott lamperd b c (before computers)
bauerhillboy
Posted 2011-03-08 3:19 PM (#355028 - in reply to #355026)
Stewmac.com
You'll find something there for sure. If you don't see a saddle ready-made to fit your guitar (...and you WON'T), they'll have a blank you can work with. You need the proper thickness. Standard is either 3/32" or 1/8". Then they have "very thick" so you can sand it down.
Then you need it to be long enough.
Then you need it to be "high" enough.
I always but 2 : )
John <>{
Tim in Yucaipa
Posted 2011-03-08 3:55 PM (#355029 - in reply to #355026)
....exactly my plan if the locals don't have blanks..... gotta find my Dremel though....
Sill haven't figured out why the Mothership uses the lousy Delrin saddles though.....
Thanks folks.
Tim in Yucaipa
Posted 2011-03-09 6:45 AM (#355030 - in reply to #355026)
...local Mom & Pop had some..... :)
